Engine wont run smoothly
Old Oct 18, 2010
2000.civic.ex's Avatar
2000.civic.ex is an unknown quantity at this point
Post Engine wont run smoothly
The engine is mis-firing. After installing a new distributor, plugs, wires, cap/rotor, timing belt, New o2 sensors and converter. I have an actron cpu and it keeps coming up with Multiple cylinder mis-fires and o2 sensors. It also says cylinder 3 &4 misfire. HLEP.
Old Oct 19, 2010
HondaHowTo1's Avatar
HondaHowTo1 is an unknown quantity at this point
Re: Engine wont run smoothly
Basically make sure you have spark, fuel, and compression. Check your spark with a spark tester, if that's good do a compression check, if you have good compression then you may have a fuel delivery issue. Also did you do your own timing belt and distributor? If so, did you do proper timing adjustments? If your timing is off your car will run like crap.
Old Nov 28, 2010
thanks!
i have it all going good now. I just have the CODE P0135 coming up for Primary o2 Sensor Heater Circuit Malfunction. I've used a Bosche and Denso sensor and now know its not the sensors but something else. HELP. I dont know how or what to do. Any Ideas?
CarStuff
Dec 6, 2020 12:52 PM
mrcell24
May 19, 2015 10:02 AM
mrohitredd
18
May 14, 2015 07:35 PM
dragonsblood
Apr 27, 2015 12:28 PM
supercivic01
South
Nov 30, 2001 11:27 AM
