Snipped sensor in place of engine block coolant drain
Old Jan 5, 2019
olivedoe's Avatar
olivedoe is an unknown quantity at this point
Heeey fellas!
2004 Honda Civic EX
Check this out, I went to drain the coolant from my block, and instead of a block drain plug, there is this (snipped!) sensor-looking jig. Both the haynes manual and BlueEM's HG guide show that this is where the block drain plug should be. Looks like someone stripped the original drain plug and improvised.
I'm trying to decide if I should get a wrench on it, or just leave it, and vac out the coolant when I get the head off. Any thoughts?
Old Jan 5, 2019
Colin42's Avatar
Re: Snipped sensor in place of engine block coolant drain
Maybe there used to be a block heater, could try a wrench on it, but if it doesn't come out easily then I'd leave it alone
Old Jan 5, 2019
Slumpertcivic's Avatar
Yea that looks exactly like a block heater.
Old Jan 7, 2019
olivedoe's Avatar
Thanks guys, I appreciate your help!
prr
Aug 16, 2016 04:51 PM
RangeRider
Aug 30, 2014 08:50 AM
crypticlineage
Engine DIY
Aug 10, 2014 08:43 AM
laack
Nov 27, 2010 03:58 PM
chickenbuster
Jan 19, 2007 10:54 AM
