am i screwed?
Old Mar 1, 2016
dakwii13's Avatar
dakwii13 is an unknown quantity at this point
am i screwed?
2002 honda civic lx manual tranny 1.7 engine 252k miles on it
so over the last month or so i've noticed my car acting weird
i was driving down the hwy doing about 70. next thing you know, the car just slows down and will not accelerate when i step on the gas. i put it in neutral and the battery and oil lights come on. i pull it aside and turn it off. wait a few minutes and it drives off again with no problems
it happened again 6 days later, same exact situation. and then again 4 days after that. took it to a shop and they replaced the timing belt and water pump as well as the seals
today i pulled out of the driveway and was shifting from 1st to 2nd gear and then into 3rd. the car jumps and slows down, and oil light and battery light comes on. i downshift and it jumps again. i pull over and turn it off, wait 4 minutes and then crank it up. it doesn't crank up at all. it turns but doesn't completely start the car. i can hear the starter trying to fire up
after waiting 10 more minutes i crank it up and drove to work 35 minutes with no problems. when i got home i replaced all the spark plugs just in case to rule out any problems. plugs i put in are ngk platinum g power
anybody know what could be happening?
Old Mar 1, 2016
Re: am i screwed?
Got oil?
Got alternator bolts checked to make sure someone didn't forget to tighten them after the timing belt job?
Got codes?
Gonna be hard to tell you anything exact, you need to figure out what goes missing when it dies...Fuel? Spark?
Old Mar 1, 2016
dakwii13's Avatar
Re: am i screwed?
Originally Posted by ezone
Got oil?
Got codes?
yep oil is good.
didn't realize alternator would have been loosened in order to do timin belt
haven't read codes, will get that done tomorrow
Old Mar 1, 2016
Re: am i screwed?
Yes, it is removed during the timing belt job. Forgetting to tighten all the alternator mounting bolts is the #1 cause of PCM failure.
So simple, so easy to forget, and so expensive to figure out and fix after it's caused damage.
Old Mar 2, 2016
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: am i screwed?
Yeah it sucks when this happens!!
It could be your camshaft position sensor. After I did my timing belt I was getting the same thing to happen when getting up to higher RPMs. Realized my alternator wasn't tight and ended up blowing the PCM.
But when the CPS would go out the car would slow to a crawl and I could turn it off and turn it back on and it would fix the problem. Wasn't getting the battery light though if I remember right but not sure.
WWJD
Sep 23, 2015 12:56 PM
BBrosario
Sep 17, 2015 07:51 PM
tomas6791
Sep 11, 2015 06:47 PM
