Leaking oil, what is this
Old Mar 4, 2015
Miseryink's Avatar
Miseryink is an unknown quantity at this point
New to working on my civic, know and work on early 90 jeeps. It is a 03 LX with a 1.7 L SOHC , standard trans. It is leaking from the round black "plug" in the picture. I am looking to see what that is so I can start researching how to fix it. Thank you for any help, kyle
Old Mar 4, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Leaking oil, what is this
When they machined the head, that was access for the tooling. Pretty sure it is just a plug. However, think you will need to pull valve cover to replace it. If all it is doing is seeping, and not dripping, just wipe it off. They usually do that. I always put just a light film of RTV gray sealer on the inner lip. Usually, the are only like a half moon in the head on older Civics and most Toyota's. I bet if you wipe up what oil you see, it may not be leaking as bad as it looks. However, it a easy fix if it is dripping. There is one in the back also. Could be the half moon one I mentioned.
Update..appears they have changed the design. In the fish, that appears to just pop out. In the OD of it is an o-ring. You should be able to replace the o-ring and snap it back in there. I do not have a service manual but was look in my 2006 Civic one and College Honda on line fish.
http://www.collegehillshondaparts.co...-manual-engine
Old Mar 4, 2015
mikey1's Avatar
it is just a plug to cover the hole where a distributor would normally be,
you dont have to remove the valve cover to replace it, but i would, along with the valve cover gasket
Old Mar 4, 2015
Honda sells the whole plastic plug with the O ring, it's less than ten bucks.
Honda part number 12513-P72-003,
USD $8.77 MSRP, (cheaper online).
Old Mar 4, 2015
Zed's Avatar
Zed
Zed is an unknown quantity at this point
As Ezone says, buy the whole plug, it comes with the O ring. You may find that once you start to remove that plug, it is brittle and breaks apart. Better to be safe than sorry.
Old Mar 8, 2015
Blaster30's Avatar
Blaster30 is an unknown quantity at this point
You should replace the EGR gasket as well. It was less than $2. But I do not see it in your pic. I am new to Civic's so maybe its a different version.
Old Mar 8, 2015
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
The A1 as his LX has doesn't have it there like our A2s do.
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
Vaguexo
Jun 13, 2015 04:11 AM
Jigee
May 9, 2015 11:18 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
