Map/maf sensor
Old Feb 11, 2013
redcar802's Avatar
redcar802 is an unknown quantity at this point
Map/maf sensor
Hi guys I just installed a universal spectrum short ram and my check engine light is on because I did not plug in my map/maf sensor.. so Im just wondering if i can run my car without it and is there a maf sensor extension I can buy because the closest insert I can use is way too far from the maf cable
thanks guys will upload pics as soon as I can
Old Feb 11, 2013
Re: Map/maf sensor
There is no MAF sensor in the 7th gen. If you installed an SRI, you shouldn't have had to touch the MAP sensor, since it's attached to the intake manifold.
If you did, in fact, unplug the map sensor and forget it, plug it back in, clear the code, and see if it comes back
Old Feb 11, 2013
redcar802's Avatar
Re: Map/maf sensor
what is the plug that is attached to the oem air filter box?
Old Feb 11, 2013
sl33pyriceboi's Avatar
Re: Map/maf sensor
Air intake temp sensor
Old Feb 12, 2013
redcar802's Avatar
Re: Map/maf sensor
Would it be a big problem if I don't plug the air temp sensor?? Is it safe to drive my car without it?
Old Feb 13, 2013
redcar802's Avatar
Re: Map/maf sensor
bump
Old Feb 15, 2013
redcar802's Avatar
Re: Map/maf sensor
Would it be a problem of I don't plug in the air temp sensor?? Any help will be appreciated
Old Feb 15, 2013
mikey1's Avatar
Re: Map/maf sensor
yes it would be a problem.....all sensors are there for specific reasons
plug it back in....if you need to drill a hole in your new intake to mount the sensor then do it
Old Feb 15, 2013
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Re: Map/maf sensor
It is important, but not drastically necessary...I just left mine plugged in and zip tied to a bracket until I finally took the intake apart and made a hole for it.
Old Feb 16, 2013
redcar802's Avatar
Re: Map/maf sensor
Thanks guys appreciate all the help! Going to drill a hole on it
Old Feb 17, 2013
redcar802's Avatar
Re: Map/maf sensor
Got an update
I ended up drilling a hole into my intake for my air temp sensor but my check engine light is still on what should I do?
Old Feb 17, 2013
Re: Map/maf sensor
get the code read. Tell us what the code actually is. Then we can help you.
Old Feb 18, 2013
mikey1's Avatar
Re: Map/maf sensor
Got an update
the light is on because you had the sensor unplugged....
disconnect your battery for 10 mins.....reconnect and start engine.....the light should be off
Old Jun 15, 2020
Jesus Delgado's Avatar
Jesus Delgado is an unknown quantity at this point
Re: Map/maf sensor
[QUOTE=xRiCeBoYx;4632460]There is no MAF sensor in the 7th gen. If you installed an SRI, you shouldn't have had to touch the MAP sensor, since it's attached to the intake manifold.
If you did, in fact, unplug the map sensor and forget it, plug it back in, clear the code, and see if it comes back[/QUOT
I have a 2004 Honda Accord 2.4L I want to install an cold air intake but I don't see a MAF sensor but I do have a MAP sensor. So I wanna know if my car have a MAF sensor? Cause I search but can't find anything
Old Jun 16, 2020
BrotatoChip's Avatar
Super Moderator
Re: Map/maf sensor
You just replied to a 7+ year old thread on a Civic forum with a question about your Accord....
To answer your question, no it doesn't have a MAF, just a MAP.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
