Timing Belt Noise?
Old May 29, 2012
jimmyjames1387's Avatar
jimmyjames1387 is an unknown quantity at this point
Timing Belt Noise?
I have greatly appreciated this forum, it has been a huge help to me in the past and hope it will be again today!
A friend, who is pretty skilled mechanically, helped me do the 100,000 mile maintenance on my 2005 Civic. We replaced the timing belt, crank seal, cam seal, water pump, auto tensioner, etc. Once we got everything put back together and ran the car I realized it was making a loud whining noise every time I hit the accelerator. The only time I can't hear it is if I let the engine slow down and idle or when the road/tire noise gets to be too loud.
The noise sounds like it's coming from the timing belt area and is driving me nuts. I'm not sure how to go about getting rid of it.
Anyone have similar problems in the past and have suggestions?
Old May 31, 2012
JackImpact's Avatar
JackImpact is an unknown quantity at this point
Re: Timing Belt Noise?
I think I am suffering from this as well. Its really annoying, especially for someone who likes to drive with their windows down.
Help us!
Old Jun 1, 2012
04 Honda Civic's Avatar
Did you use quality parts?
Did he accidentally over tighten the drive belts maybe?
Old Jun 3, 2012
jlindell's Avatar
jlindell is an unknown quantity at this point
you over-tightened one of your drive belts it sounds like
Old Jun 18, 2012
We used quality parts and it still makes the noise with the alternator and power steering belts taken off...any other thoughts? I have everything taken apart but can't figure out what's causing the noise. Anyone know the torque specs for the tensioner bolt?
Old Jun 18, 2012
It sounds to me like the timing belt is too tight?
Old Jun 18, 2012
Thanks! I believe that you were right. I tightened the auto-tensioner bolt to 33 foot pounds, which I found as the spec on a DIY timing belt forum from this site but it made a lot of noise. I backed it down to between 15 and 20 foot pounds and it sounds a lot better.
Old Feb 15, 2013
This response is extremely delayed, but thanks to all those who helped me figure out the timing belt noise last summer. The kit I bought was missing a new auto tensioner spring and the old one got bent. The belt was waaaaaay too tight and I learned backing it down to 15-20 foot pounds (when it calls for 33) was not a good idea. We replaced the spring and it runs great.
Just FYI for anyone that runs across this thread with a similar problem...
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
