considerable oil loss, but no puddle underneath
Old Apr 6, 2010
Pongo08's Avatar
Pongo08 is an unknown quantity at this point
Exclamation considerable oil loss, but no puddle underneath
So i have an oil leak. i wouldnt call it major because lucas oil stops it, but thats only a bandaid. i have have to add it every time i change my oil. if i dont add it i lose about a quart every 2 weeks. i drive pretty rough occasionally, i.e. revs up to about 6ish. on the daily drive i shift around 4. EVERYTHING has oil on it. its obviously from the top down. im not burning any oil. even though i had the head cover gasket replaced when i got it about 12k miles ago, it looks like it could be leaking from one half. and now the part thats gonna make you cringe... like i said theres no puddle under neath the car, so i found out about the leak the hard way. meaning i went to drain the oil and less than half a quart came out. the check engine light is not on, neither is the maint req'd light. please help?
Old Apr 6, 2010
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: considerable oil loss, but no puddle underneath
where is it leaking from? spray everything with brake cleaner. get that engine cleaned up and figure out where it's coming from. if it's that much, either you're burning it out or you have a major leak. i.e. the headgasket...
Old Apr 7, 2010
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Based on what you describe I would guess valve cover gasket. You said you had it replaced 12k miles ago but the guy may have done a poor job or the bolts holding the valve cover may have loosened. I would follow baron's advice and clean the engine and then watch for a leak. I have never used it but they make a dye that glows under black light that can be added to oil to help find the source of the leak.
Old Apr 9, 2010
Pongo08's Avatar
alright, ill try to clean it up asap and let you guys know what i find.
Old Sep 1, 2020
John White's Avatar
John White is an unknown quantity at this point
same bro, what was the issue?
Old Sep 2, 2020
BrotatoChip's Avatar
Super Moderator
This is a 10 year old thread, create you own if you want help.
JohnnyBxo
Nov 12, 2015 03:04 PM
breanna_17
Jul 21, 2015 04:01 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
671civicLX
Jul 4, 2015 04:02 PM
