No Power to fuel pump
Old Oct 15, 2023
Bearpaw's Avatar
Bearpaw is an unknown quantity at this point
Hello all
I have an issue with no power to fuel pump.
2003 civic m/t
Looking for fuel pump relay. Looked behind glove box and there are only two relays a blue and brown. Everything I have seen the fuel pump are the two black relays to the right of the blue and brown ones. What am I missing.
If I put power to fuel pump at the pump connector with my power probe and jumping the ground the fuel pump kicks on. So the fuel pump works. Fuse #17 I believe is good. Any help would be greatly appreciated! Thanks all.
Old Oct 15, 2023
Bearpaw's Avatar
Re: No Power to fuel pump
Originally Posted by Bearpaw
Hello all
2003 civic m/t
Update… jumped power at blue relay and got power at pump. Plugged in relay nothing. Replaced relay still nothing.
Old Oct 16, 2023
Colin42's Avatar
Key on the dash flashing?
Old Oct 16, 2023
Bearpaw's Avatar
the key on the dash illuminates green when key is turned to the on position then goes out after 2-3 seconds
now I removed the ecu from behind glove box. And inspected reinstalled and no key light at all.
David Mckenzie
Nov 3, 2019 04:35 PM
crazyone64
General
Apr 16, 2019 12:52 PM
brianturbocivic
May 4, 2005 11:07 PM
cosmo
Aug 11, 2004 05:00 PM
