Honda Civic 1.4LS (2001)
Old Sep 13, 2021
Eduardo96's Avatar
Eduardo96 is an unknown quantity at this point
Hi everyone,
First and foremost thank you for any help or advice given here, you guys rule.
I have two electrical related problems:
1) Previous owner changed the front passeger seat, SRS came up. I've checked the connections under the seat. I've reset the airbag light under the drivers weel, in the fusebox's yellow cable and SRS is still ON, I'm assuming it's something related to the replace seat. P.S. Car has side airbag.
2) Door lock buttons on the right front and back passengers don't go down electrically, when pressing the drivers button, but rear left passenger button does. I've opened the doors and check the actuators, finding this:
The bottom cable has two metals pins on the female side that connects to the male, but, as you can see the upper connection on the actuator has no electrical metal pins to connect the cable to. On the rear left passenger seat, the actuator has pins on both these plugs. Is this some cheap replacement actuator? Is there anything I can do or must I buy new ones?
Previous owner barely said he disabled the door switches somehow, because of his kids not opening the door. Weird explanantion now that I look at it.
P.S. Dome light comes ON when I open any of the referred doors.
Kindest regards,
Eduardo
Old Sep 13, 2021
Eduardo96's Avatar
Re: Honda Civic 1.4LS (2001)
Also, there's this unconnected cable on the front passenger door.
gnurmi
General 7th Gen
Jun 18, 2018 08:46 AM
DeX
30
Jun 7, 2008 07:41 PM
whiteboy87
18
Oct 13, 2007 10:30 AM
injencivic
Mar 25, 2004 11:18 AM
