Need some help with 04 Civic troubleshooting steps!
Old Sep 26, 2020
Erin Enns's Avatar
Erin Enns is an unknown quantity at this point
I have a manual 2004 Honda Civic DX sedan that I recently bought. It had keyless entry (working with no problems). It had an aftermarket stereo in it already, so I wanted to update it further, got a new one installed and everything was great. There were no problems, then about a week or two after my passenger window stopped rolling up from my driver side control panel (The passenger side control switch is completely fine, rolls up and down with no problem). Then a couple days after that my keyless entry stopped opening and closing on my rear passenger and driver door, couple more days and now the manual switch doesn't work either (only the two doors, it works on the others). I figure the door actuator replacement first and if the problem isn't resolved, is it possible to override/replace the original keyless entry with a newer model with command start so I can up my keyless range and get command start? Then what do y'all figure with the window? Need a new driver control panel?
Old Sep 26, 2020
Colin42's Avatar
Re: Need some help with 04 Civic troubleshooting steps!
Check for broken wires in the door harnesses
Old Sep 28, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Especially the driver's door harness in the area between the 2 hinges as this gets the most use over time. This issue has happened to me a couple of times now.
SKcivic
Electronics
Apr 8, 2020 10:40 AM
rdp1408
Nov 11, 2010 09:59 PM
Civic04u
May 12, 2008 11:31 PM
MugenxSnowman
South Cali
Apr 13, 2007 01:18 PM
MegaCivic2k1
Jun 4, 2004 12:36 AM
