Radiator fans don't kick in with a/c on.
Old Mar 21, 2020
AangAirbender's Avatar
AangAirbender is an unknown quantity at this point
Hey guys, I have a 2002 1.6 hatchback EU, I have never seen the radiator fans going. I bought the car at winter so I was sure it is because the temp was low. But today I wanted to try the a/c since the temp was 20 C, but it did not work. The fans did not spin, the compressor clutch did not engage. I put a jumper into the fan controller and they work.
Could you guys help me where to start?
P. S.: I checked the coolant temp, it did not go above 84 C while driving.
Thanks in advance and sorry for my bad english.
Old Mar 21, 2020
Slumpertcivic's Avatar
Re: Radiator fans don't kick in with a/c on.
I would first check for pressure in the low side AC line.
Then I would check the AC pressure switch.
Then I would check all fuses.
If the AC clutch is not energizing then don’t even worry about the fans, the problem is likely elsewhere.
Old Mar 21, 2020
I checked the fuses and switched all relays with the horn relay, fuses are ok, horn works with all the relays.
Old Mar 22, 2020
When I jump the clutch relay, it engages. Same with the fans.
Any idea where to see now? I am about to check the low line tomorrow.
Hayden_Fourroux
May 16, 2020 03:35 PM
SuperEF
Jun 24, 2015 11:53 PM
crisss
Mar 19, 2013 11:19 AM
Tinkerbell_too
Dec 24, 2010 12:48 PM
CincyBlck2k1
May 4, 2007 10:16 AM
