Sunroof doesnt work?
Old Nov 30, 2011
rileyb22's Avatar
rileyb22 can only hope to improve
My girlfriend has a near mint 2004 civic ex. The sunroof worked when she got it but after about a month, it stopped working. There are no blown fuses. Has anyone else had this problem? Could there be a bad switch?
Old Dec 1, 2011
rjones7755's Avatar
Re: Sunroof doesnt work?
Have you tested the relays?
Old Dec 1, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Does it do anything at all when you push the button? Does it make a grinding noise or any noise at all?
Old Dec 1, 2011
rileyb22's Avatar
I have not tested the relays. Right after it stopped working it would make a noise when you pushed the button, like a click, and now there is no noise at all.
Old Dec 1, 2011
Gunner's Avatar
The lack of noice means the motor is not running or is burnt out, either you have no power going to the motor or its shot. Check relays connections..
Old Dec 3, 2011
stoehe's Avatar
stoehe is an unknown quantity at this point
I have a 2002 CIvic EX and my sunroof is slow as hell right now....sooo its getting there.
Old Dec 3, 2011
civydcex's Avatar
civydcex has a spectacular aura aboutcivydcex has a spectacular aura aboutcivydcex has a spectacular aura about
I have a 04 civic also and replaced the switch and it worked. About 6 months later same thing, didnt work so i just said the hell with it!!! There is something funky with these cars!! My back windows didnt work then did one day. I guarentee its not the relay. Dont waste your money. Switch for sure!!! Or a loose connection on the sunroof motor
Old Dec 4, 2011
K20Z3's Avatar
2010 Civic Si
K20Z3 is on a distinguished road
Did you check the flux capacitor? Those things are known to go bad sometimes.
Old Dec 9, 2011
civydcex's Avatar
Could also be the sunroof fluid is low!! Or the switch bearing!!
Old Dec 9, 2011
Gunner's Avatar
^ Nice LOL.. I will see if I can find a DIY on filling the sunroof fluid resevoir..
Old Dec 9, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
Could be the operator valve is bad and needs to be replaced.
Old Dec 16, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Get to someplace quite and pust the button by the change holder and listen for a click at the moonroof. If you hear a click up around the sunroof its not the switch.
Old Dec 16, 2011
Heiserb's Avatar
Heiserb is an unknown quantity at this point
Where do you add/ check sunroof fluid? just bought an 03 ex today
Old Jan 4, 2012
kerrymm's Avatar
kerrymm is an unknown quantity at this point
Where are the open/close relays for the sunroof? They're not on my fuse diagram. (04 civic si)
thanks...
Old May 16, 2020
Perevon Kong's Avatar
Perevon Kong is an unknown quantity at this point
I have a 09 civic lxs sedan and my sun roof doesnt open or close tried to find fuse and relay dont know where it is makes no sound when trying to use the switch. Could it be broken cause of the sun roof motor.
Old May 16, 2020
Colin42's Avatar
Owner's manual will tell you where the fuse is
Old Sep 3, 2020
DJ Smith's Avatar
DJ Smith is an unknown quantity at this point
I have a 2004 civic ex when I press the sunroof button I hear a faint click sunroof wont open first thing would be to check relays
roverben
Jan 21, 2019 05:16 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
ashlava71
May 16, 2015 12:54 PM
ORskier
May 3, 2015 12:54 PM
Jandree22
Dec 13, 2001 03:23 PM
