Intermittent electrical problem 02 Civic
Old Oct 27, 2010
entensity's Avatar
entensity is an unknown quantity at this point
I have a intermittent electrical problem that is driving me and my mechanic buddies nuts. 2002 Honda Civic HX
It happens a few times a month. I will be driving my car and Ill hear my radio cut out for a split second which lets me know it is happening. So if I hit my brakes or turn on my heat or AC everything cuts out for a quick second. The lights go dim, the radio shuts off then back on right away, and all my gauges go down along with the SRS light coming on. But everything comes right back on in less than a second.
Now it may cut off a few more times by hitting the brakes or turning on the heat or AC but the problem will only go on for a few minutes then it does not come back for weeks sometimes months. The problem never leaves me stranded, it only cuts out for less than a second, its never enough to kill the engine. I replaced the alternator and load detector, cant think of what else it could be.
Any suggestions would be greatly appreciated, love my Civic
Old Oct 31, 2010
mrchowmein's Avatar
mrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura aboutmrchowmein has a spectacular aura about
Re: Intermittent electrical problem 02 Civic
thats happened to me before. it usually happens if i run alot of electrical stuff while the car is at low speeds or idling. do you have any electrical mods? such as a subwoofer, fog lights, etc? it might be that your devices are just draining too much of the battery and the alternator cannot keep up.
dealer couldnt figure this out either, but it was solved when i got a better battery, the stock one sucked.
Old Nov 2, 2010
entensity's Avatar
No, my car is completely stock, and like I said, it is random, I can never get it to happen when I want to... it only happens a few times a month.
Old Nov 2, 2010
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
I was having the same problem with my car over the last week. All of my dash lights would come on and then the power would gradually go out (gauges, radio, lights, etc.).
When I put a meter on the battery it read about 12v with the car off. When the car was running with all electronics turned off it was 13v which is a little low. Typically, it should be in the 13.5 to 14.5 range. When I turned on a few things the voltage dropped to the low 9's...
I got the alternator replaced today. Hopefully it fixes the problem but from what I've been reading it may not...
Old Nov 4, 2010
entensity's Avatar
Sounds like a alternator is your problem, but my problem is much different. It is very random, sometimes only happens 1 time a month. My car goes into this "mode" where I can hit the brakes or turn on the heat / AC and it will cut out for a second.. then it wont do it for a month or so...
Old Nov 4, 2010
lazlong's Avatar
Check all your grounds.
Old Mar 21, 2011
sirtopemhat989's Avatar
sirtopemhat989 is an unknown quantity at this point
Has anyone figured this out. This is exactly what is happening with my car..
Old Mar 21, 2011
lazlong's Avatar
^^ See my last post.
Old Apr 22, 2012
justinnc's Avatar
justinnc is an unknown quantity at this point
Im having the exact same problem. Has anyone figured this out? Please share if you know what is wrong.
Old Apr 22, 2012
CraigW's Avatar
See above.
Old Apr 14, 2021
Steve Mado's Avatar
Steve Mado is an unknown quantity at this point
Hey, im having this issue now, were you able to solve this issue ?
if yes, what did you do ?
please help
Old Apr 14, 2021
BrotatoChip's Avatar
Super Moderator
9 year old thread...
HondaFan2001
Nov 18, 2014 09:07 PM
Experiment 626
Oct 20, 2014 12:10 PM
imanoob
Nov 11, 2013 05:08 PM
cashtein
21
Dec 29, 2011 06:15 PM
Hanzo
Feb 1, 2008 11:17 AM
