Intermittent Gauges
Old Mar 19, 2006
smitty29832's Avatar
smitty29832 is an unknown quantity at this point
Intermittent Gauges
My wife has a 2001 Civic EX. A few months ago the gauges (speedo, fuel, RPM, etc) began to shut down intermittently. At times they will not work for days and all a sudden they will turn back on and work for awhile. Could it be a bad relay? Any suggestions would be appreciated. Thank you.
Old Mar 19, 2006
usually this means you have to replace the cluster. mine started doing this randomly too and i just got annoyed and swapped it out. there's dime a dozen on ebay.
Old Mar 19, 2006
You mean the entire instrument cluster will need to be pulled and replaced? I though it was an electrical issue.
Old Mar 19, 2006
streetglower's Avatar
any electrical issue involving the cluster assembly will usually require the replacement of it. Now if there is only one small problem like a malfunctioning fuel gauge, then there are other means to fixing it without replacing the cluster. the circuit board is inside of the assembly and cant be replaced seperately if a issue occurs with the circuit board. now before doing anything, possibly check your connections on the back of the cluster assembly. if those are good, there is a test procedure for the cluster to determine if it is faulty that I can try and find for you. or ask craigW to send you the information from the manual, he can download it and send it to you.
Old Mar 19, 2006
Sounds good. Apparently this is more of an issue than I thought. Given that, several questions come to mind; How do I access the back of the cluster to check the connections? What is the process of replacing the cluster with a new and/or used one and how will a different cluster effect the actual mileage?
Old Mar 19, 2006
oh yea there is a gauge calibration program that sweeps the needles. new cluster will replace the mileage of the old one. it is stored in the cluster rom chip.
Old Mar 21, 2006
FOOP's Avatar
FOOP is an unknown quantity at this point
I had that same problem. My Check Engine Light was also on at the time which I had read at AutoZone. The code that came up was for the Vehicle Speed Sensor. I did a little more searching on the web and found that a bad ground in the engine can cause this to trigger. I replaced the ground wires in my engine bay (they were completely oxidized) and reset the car (done by disconnecting the + and - from the battery and holding them together until there is no power left in the electrical system of the car, about 30 sec., then reconnecting them to the battery). Needless to say, the speedometer has been fine ever since.
Old Mar 21, 2006
ya i've been finding out that the factory grounds on this car are terrible, especially after a couple years they are all messed up.
Old Jul 26, 2006
stylesabu's Avatar
stylesabu is an unknown quantity at this point
I'm Also Having This Problem.i Just Leave Dash Bezel Off.and I 1st Tap On Cluster, If That Doesn't Work I Pull One Of The Connectors Off,and Plug It Back In That Always Brings It Back To Life.its Only 5 Screws To Remove Cluster
Old Jul 27, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Mine went out today. Abs light came on for no reason, then I turned my AC on and the instruments died. I turned my headlights off, then everything came back on. Dunno if its the cluster or alternator or something.
Old Nov 24, 2018
skbetts47's Avatar
skbetts47 is an unknown quantity at this point
Angry Re: Intermittent Gauges
CLUSTER GUAGE TEST PROCEDURE
1. Push and hold the trip/reset button.
2. Turn the lighting switch ON (ACC ONLY).
3. Turn the ignition switch ON. (ACC ONLY - don't start)
4. Within 5 seconds, turn the light switch OFF, then ON, then Off again.
5. Within 5 seconds, release the trip/reset button, then push and release 4 times more.
Takes a try or 2 to get it. The odometer has to be in mileage mode, NOT trip mode when you do this. All the needles will sweep back and forth once. To exit, turn off the ignition. Just push the trip button again to see the needles sweep again while in test mode.
Old Nov 24, 2018
skbetts47's Avatar
1. Push and hold the trip/reset button (must be in Mileage Mode not Trip node).
Sprx26
Jul 26, 2016 09:11 PM
installer23
Jul 21, 2015 04:20 PM
04_Civic_SE_NB
Jun 15, 2010 09:08 AM
bigmax1665
28
Apr 26, 2007 12:09 PM
civic7gen
Jun 13, 2004 12:35 AM
