Regular Maintenance Post questions about regular maintenance here
Transmission Flush Question
Old Jan 29, 2020
tristar76's Avatar
tristar76 is an unknown quantity at this point
Had my A17 service done at the dealership the other day (40,000 miles). Of course when I left, they had a list of recommended service items, one of which was a transmission flush. The quoted cost is $275.00.
Number one, that sounds insanely expensive. I like to use this dealer for service because it's uber convenient, but I feel like I'm getting taken here.
Number two, does Honda even recommend transmission flushes? I've seen forum posts mentioning just draining and refilling.
Old Jan 29, 2020
BrotatoChip's Avatar
Super Moderator
Re: Transmission Flush Question
40k miles sounds about right for transmission fluid change, $275 seems a bit steep. Don't know what year/trim you have but the 2016+ with the CVT only gets a drain and fill. The fluid is pretty pricey though, if I'm remembering correctly ~$15 a quart and you need four.
Old Jan 29, 2020
tristar76's Avatar
2017 EX-T, so you are correct.
Old Jan 30, 2020
CraigW's Avatar
Hondas idea of a "flush" is multiple drain & fills.
At 40k this should not be needed..... just an OEM fluid change & drive on.
Strange that a Honda dealer would recommend a flush though....
Old Jan 30, 2020
tristar76's Avatar
Just got off the phone with the dealer. I specifically asked him if Honda recommends flushing the CVT, and he said "well, a lot of people just drain and fill." It seems to me they're just trying to sock me for money. Shocking.
Old Jan 30, 2020
Super Moderator
On a regular automatic trans the torque converter holds fluid so when a drain and fill is done only about half the total amount of fluid is replaced. A couple more drain and fills are then done to get the fluid as new as possible. My understanding is with a CVT all the trans fluid is drained at once because there is no torque converter. So a simply drain and fill is sufficient.
Old Jan 30, 2020
tristar76's Avatar
Interesting, since when I asked the dealer to describe the flush, he specifically mentioned cleaning the torque converter. More evidence that a) they don't know what they're talking about, or b) they want to do the flush because it's profitable. I called another dealer and they quoted me a drain and fill straightaway. $100. Sold.
Old May 17, 2021
Neo2070's Avatar
Neo2070 is an unknown quantity at this point
What about the transmission filters? When do they need to be changed and where are they located?
Old May 18, 2021
Colin42's Avatar
You have to pull the trans apart to get it, good luck with that
Old May 20, 2021
Neo2070's Avatar
You are mistaken the transmission filter is located under the transmission in the transmission oil pan. Once you remove the pan it is easy to get to. My question is how often does it need to be replaced and if you remove the pan does it require the same amount of fluid if you remove the pan as opposed to a drain and fill?
Old May 20, 2021
Colin42's Avatar
Well that's new, for years they never had an accessible pan. I would change it at 160k kms.
probably need about 3 qts of fluid
Old May 11, 2022
angelo91's Avatar
angelo91 is an unknown quantity at this point
Hello everyone. I wonder if any of the dealerships ever changed the Transmission filter on my car. I did see on YouTube that it isn't that hard to get to. It's just below the air filter but takes some tools to get to it. I have almost 150K miles on my 2011 Civic and wondering if can get away with a Drain and Fill rather than a Flush. The book didn't say anything about a Flush so just wanted to check with everyone here. Thank you.
Old May 11, 2022
FRSam's Avatar
Click Here
You don’t flush transmissions. That runs the risk of knocking things loose and doing more harm than good. Drain and fill only.
Old May 11, 2022
angelo91's Avatar
Thank you so much!
alaga
Aug 7, 2015 06:28 PM
mjomasta
Aug 3, 2011 02:45 AM
return_2020
Dec 16, 2004 11:41 PM
02NCcivic
Feb 11, 2003 04:15 PM
silverride
Nov 26, 2002 02:38 PM
