Regular Maintenance Post questions about regular maintenance here
Oil Change Codes
Old Feb 23, 2017
dferguson21009's Avatar
dferguson21009 is an unknown quantity at this point
Oil Change Codes
I've had my civic for 15mos, I got my first oil change at the 11mos mark w/ 3300 miles. Oil change and tire rotation at dealership where purchase. I now have 5k miles and the oil change code B1 just showed up on my screen.
Is there a way to reset this code or do I have to go get another oil change?
Thanks
Old Feb 23, 2017
Re: Oil Change Codes
Thanks
First thought.....Someone didn't reset the maintenance minder when they did the first oil change?
Next thought....some of those had weird things happen......Does your car have a touchscreen radio with wifi capability?
Is the oil change reminder showing ONLY on the radio? Not showing on the center of the tach?
Old Feb 26, 2017
No touchscreen display... reminder only center of tach. I would have thought dealer that did oil change would have reset minder, that being same dealer I purchased veh.
Old Feb 26, 2017
CraigW's Avatar
2015 ??
What is the percentage left ??
9ths gens show the due items upcoming in the display.
Old Feb 26, 2017
2016... 70%
Old Feb 26, 2017
If it's showing 70% right now, I'm pretty sure it was reset by whomever did the service.
At 70% there should not be any reminder unless you brought up the display yourself using the steering wheel buttons (probably the small round "I" and enter buttons). Right now it's showing you what items would be due at the next service interval (B1).
The reminder comes on by itself at 15%.
Old Feb 26, 2017
CraigW's Avatar
I would say those are upcoming items/codes displayed. (like my 2013)
And, that it was reset when the work was done previously.
Old Sep 5, 2018
ducebigalow's Avatar
ducebigalow is an unknown quantity at this point
I have a 2017 civic hatch lx, and when I check the reminder myself (under the wrench) it currently says 50% but there is also a number of 019 under that? Any ideas what this might be? The car is approaching 20k and it has had the first oil change earlier in the year.
Old Sep 5, 2018
GolNat's Avatar
Prelude Owner
Did you look in the manual? Might be upcoming maintenance stuff.
Old Sep 5, 2018
You have both a 2017 AND a 2018?
Can you post a pic of this?
Old Sep 6, 2018
Opps, no I only have an 2018 hatch lx. I get a pic and post it for yah.
Old Sep 8, 2018
Here is a pic of the dash under the maintenance
Old Sep 12, 2018
I still don't have an answer on that, and I really don't have anything on canada specific info either.
t looks to be the usual location you would see the upcoming service item codes, but ours (USA) would only be able to show the characters A/B , 12345 and 7. No 0 or 9.
Doesn't your car have touchscreen radio? Pull up the maintenance minder on that unit (home>settings>vehicle, scroll to the bottom for maintenance) and see if it agrees with what the display on the gauges is telling you.
Old Sep 17, 2018
The 019 stands for;
A1 which is the oil change
and the 9 is the brake inspection, tire rotation.
I looked it up under the links you mentioned.
Thank you
Shawn
Old Sep 17, 2018
The 019 stands for;
I still want to know if that zero showing is normal. I don't remember ever noticing it on any that come in our shop. Maybe it's Canadia only?
Old Sep 18, 2018
Colin42's Avatar
I don't think I've ever seen it, I've seen the As and Bs
Cameron Schudy
Aug 15, 2016 08:41 PM
SidCivic
17
Aug 23, 2015 03:14 AM
06CIVIC_US
17
May 20, 2007 01:15 PM
slick
Oct 7, 2002 09:56 PM
ProDigy
Sep 7, 2002 10:15 PM
