Canada West Saskatchewan, Alberta, British Columbia, Yukon, NWT
Painting Calipers....help
Old Oct 21, 2002
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
ok i want to paint my calipers but i wanna know what paint i should use (brand name), the price and where to get them. and also anyone want to help me do it?[IMG]i/expressions/face-icon-small-smile.gif[/IMG]please[IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Oct 22, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
ya i could help you, but it's funny cuz civics have rear drums so you only going to paint your front calipers?
I did mine already on my Protege 5.
here's what you need.
1) From Canadian Tire or Lordco - High Temp Caliper paint. Either spray or brush.
2) Foam brushes, small and wide.
3) masking tape
4) Paint thinner
5) Sand paper - fine.
Step 1 Take off your rims/steelies
Step 2. Sand paper the caliper to get rid of the rust/dirt etc.
Step 3 . Use paint thinner to remove all the dust and stuff from the sanding.
Step 4. Put newspaper and masking tape around the edges that you don't want paint on.
Now caution: Caliper's slide on two pins. You should be able to see part of the sliding pin. IF you get paint on it
it may not slide as well and your brakes will be fvcked so be very careful.
Step 5. Spray paint into the lid of the spray paint can and use foam brush to apply several layers *allowing each layer to dry* Don't let the paint run. Dab it.
Step 6. Once dry 1-2 hours put the wheels back on and let it dry for several more hours before take it out.
If you scared to do it we can set up a mini paint caliper meet or something.
Old Oct 22, 2002
skc's Avatar
skc
skc is an unknown quantity at this point
i want to paint my calipers too.
let's have a paint caliper meet so we can do it together.
Old Oct 22, 2002
Super Member
hey thanks noddleboy. yeah, we should have a small meet sometime.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 17, 2003
orion_squall's Avatar
"Now caution: Caliper's slide on two pins. You should be able to see part of the sliding pin. IF you get paint on it
it may not slide as well and your brakes will be fvcked so be very careful."
what do we do to avoid paint get into the 2 pins? please be specific, thanks!
Old Apr 19, 2003
jefff's Avatar
jefff is an unknown quantity at this point
If you are the type of person that has never had their wheel off, exept to change a flat. I would recommend having someone who has help you with this.
Not trying to be an ***, just don't want any out of control, but colorful drivers on the road.
Old Apr 19, 2003
JDQuikCivic's Avatar
JDQuikCivic is an unknown quantity at this point
Hey Steve,
I'm painting my calipers pretty soon to go with my rims. Let me know when you want to go do it.
Old Apr 19, 2003
murd0c's Avatar
murd0c is an unknown quantity at this point
Jeff, Steve let me know I wanna paint mine as well!!
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
