Canada West Saskatchewan, Alberta, British Columbia, Yukon, NWT
attn: toasty
Old Feb 15, 2002
tcneo's Avatar
tcneo is an unknown quantity at this point
attn: toasty
hey toasty... can u help me sometime later with a DIY projector replacement for my headlight ? I'm plannin on installing one of this to replace my existing headlights.... still in planning stage though..
let me know.. thz
ps: Link fixed now :þ, man u sure do wake up late... LOL (based on info from tsunami... blame him.. *pointing at tsunami*
Old Feb 15, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
link doesn't work.. quick quick! fix it, before he wakes up!
Old Feb 15, 2002
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
hmmm nice nice...so like you have projectors already but your just putting these replacement heads in???
Old Feb 15, 2002
tcneo's Avatar
nope.... as u know EL's headlight is slightly different from civics, so i'll have to really do some major custom work here.. open up the headlight housing.. cut the back part of the housing.. and plug in the projector assembly. and the way the HID is assembled... my high/low beam is hooked up to the HID... so no DRL
that's why i might need to install a fog light of some sort and then use it as my high beam.
don't believe what ppl say that you don't need high beam if you have HID, because with improper housing.. you'll have to aim it slightly downwards and thus reduce it's effectiveness on highways, for city driving it's ok....
thats why i want to get the projector.... so that i can aim it upwards a little bit... without producing too much glare and it'll be much better for highways too.
ps. u can replace your projectors too (in case if your projector head doesn't satisfy you)... coz this one is made by hella.. and it's pretty good for HID's & normal halogens, it has a sharp cutoff beam pattern.
Old Feb 16, 2002
toastyghosty's Avatar
toastyghosty is an unknown quantity at this point
yeah shouldn't be a problem...although they only headlight mods and tinkering i've done is with non-hid.
and better be carefull aiming those hid's or if you ever get VI'ed then tis be a big pain in the buttocks to fix it etc....
Old Feb 16, 2002
tcneo's Avatar
hehehe thz man.. i'll let u know when i have the parts...
and by then you'll be able to say that you have the experience with HID .. hahaha
Old Feb 16, 2002
TaiChi's Avatar
TaiChi is an unknown quantity at this point
Tcneo:
Did u try your relationships with friends and make them let u to try on the 2k1civic projector on your car?
I always think that it might fit even the corner of it is a bit differnce...
Old Feb 16, 2002
tcneo's Avatar
the problem is... even if I use civic's projector.. it won't be of much use..
because my high beam cable is linked to the HID aswell... to prevent it from restarting if I hit the high beam (problem with cars that use single headlight for high & low beam, current is being cut off from the low beam when high beam is on)
and based on the wiring diagram... the only way for me to get high beam is by installing fog lights or aux lights of some sort...and use manual button to turn it on
and the beam pattern for those projector some said that they are not that good coz they are meant for halogen bulbs..
so i decided to just go with this hella thingy... it have a sharper cutoff ... more like E-Code lights.... and it's DIY !!... nobody else will have the same configuration ... LOL.... we all are trying to be different rite... ? hahahaha...
but on second thought... hmm it might work.. and i'll just wire the high beam manually then.. any volunteer ? to lend me your headlights to see whether it fits ? [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 16, 2002
ASIANPRIDE's Avatar
GODLIKE
Man I wish that I could let you try...but I'm in Edmonton...cuz I have been wanting to do up a DIY Lower Grill...and well I would need to take off my bumper...and well then I could kill 2 birds with one stone..... If you drive out here....I will 100% help you with it...I have cleared my headlights...so moding them to fit the hella wont be that difficult.......The only prob I think that you will have is....cutting a nice perfect circle into your OEM headlight assembly cuz well all that Chrome stuff on the inside will be a very big pain....So you know it may start to splinter....or chip off when you start to cut thru...I suggeset....using a Drill to cut around Circle out to fit the MODS....or a router (sp) or a dremal or somthing like that.....cuz a saw is going to do major damage...All I Know is that the chrome on the inside is thing...and probably flakey....cuz I got some of the lovely grey sticky stuff on it....and I attempted to rub it of....and well I started to rud the chrome off....Well I wish you good luck....and I'm still jealous that you got HID
Old Feb 16, 2002
tcneo's Avatar
haha thanks for the info man.... i'll take note of it..
Eman
17
Jan 31, 2009 08:30 PM
RHCP0801
Oct 11, 2006 10:38 PM
DMikeX
South Cali
Jun 27, 2005 01:51 PM
truehonda
35
Jan 26, 2005 09:51 AM
RIC3BOY
Aug 18, 2003 10:16 AM
