Rear Speaker Install
Old Jan 18, 2002
Eman's Avatar
Eman is an unknown quantity at this point
I installed a pair of Polk 6x9 in the back and followed the DIY provided by toasty ghost. Thank you! For those who are changing the speakers, when you get to the part where you need to take the speakers out, a faster and simpler way is to use a 5/16 side battery terminal wrench especially for the screws located closest to the rear window....AND make sure you follow the DIY instructions step by step
Old Jan 18, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
cool thanks [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 19, 2002
Voiceofid's Avatar
End Bringer
i was looking under the 6x9 yesterday, and noticed my trunk spring by the 6x9 are changing from a blackglossy colour to a dead grey... i try rubbing it off, no success. think it's the 6x9's magnets sucking the metal off of it?
Old Jan 19, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
where is the DIY for the rear deck cause i tryed it and i dont know how to get it off with out takin just about all the interior out???????? HELP !!!!!!!!!LOL
Old Jan 20, 2002
Eman's Avatar
Hey BlueIc, go to toastyghosty's web page www.madstatic.com/2k1civic and click on DIY. You basically would have to take the whole rear section out. Good luck and enjoy. It was a good feeling after doing it.
Old Jan 20, 2002
thanks Eman
damn thats what i didnt want to do!!!!!!!!
i might just have someone do it for me too much work
Old Jan 20, 2002
Eman's Avatar
Aight
Old Jan 26, 2002
silverbeast's Avatar
silverbeast is an unknown quantity at this point
hey eman, thanks for the info, i have kenwood 6x9's for the rear and i've been trying to figure out how u get the old ones out. I went by circuit city here in woodbridge va and they said it would take them 5 hours to do that project ? i just looked on that site you gave the other guy, i dont see anything about taking the stock rear speakers out and putting in new 6x9's cause it was hard just to get the front ones out you had take out those nasty clips
Old Jan 26, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
silverbeast.. if you followed the DIY for removing the rear deck, it would be obvious as how to remove the speakers. if you have ever seen a speaker before, you can pretty much figure that there will be for screws, most likely phillips and will commonly be hex shaped so a ratchet set would be able to remove it as well.
in any case, there are 4 screws holding down each speaker. to remove the speaker.. you will need to unscrew the screws. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 27, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
i put pioneer 6x9s in the back and i will never try to do that again, i will pay someone to do it next time!!!!
Old Jan 27, 2002
hey todd email me scottcivicVA@aol.com those are the same rear speakers im gona be putting in pioneer 6x9's help me out
Old Apr 20, 2004
dan502's Avatar
dan502 is an unknown quantity at this point
That guide at Ghosty's is perfect. Thanks for the link.
Old Jan 30, 2009
dan72987's Avatar
dan72987 is an unknown quantity at this point
Re: Rear Speaker Install
The guide at Ghosty's works great tells u everything u need to know. I just replaced the rear speakers in my civic but on the Ghosty's site it says it will take 15-30 mins, i doubt that it took me about an hour and a half. It was my first time doing that though. Just wanting to let everyone know it takes at least n hour to take it all out and then put it back together.
Old Jan 31, 2009
elementalchain's Avatar
elementalchain is an unknown quantity at this point
Smile Re: Rear Speaker Install
I had bought 6x9 Alpine Type R speakers at Best Buy and they were going to try and charge me and extra 100 bucks on top of what i was already paying to install the rears. I said no way and returned the speakers. So i guess i may remove everything from the rear before i go get the speakers installed becuase i know nothing about wiring up speakers unless anyone is willing to help.
Old Jan 31, 2009
kcari's Avatar
its not that hard - u need a ratchet or a socket wrench for the bolts and heres a DIY that I used. It took me a long time in the beginning - like 6 hours with plenty of breaks and other noob reasons. The second time I did it, took me about an hour. As far as wiring that is pretty simple too if you invest in connectors as shown here (https://www.civicforums.com/forums/2...upe-sedan.html)
that way you dont have to cut the oem harness. And even if you do decide to cut the oem harnesses (like me) you can always get female connectors and crimp them to the wire and hook them up to the male prongs accordingly (+/-) wise
heres the DIY that i used
http://2k1civic.madstatic.com/2006/0...the-rear-deck/
A lot of the panels will just require a little force, but becareful not to break any of the clips. You likely will have a rattle so you might want to invest in some patting. I used cut up socks and kitchen sponges because I am poor.
if you have any further questions feel free to post
Old Jan 31, 2009
Thanks a bunch. I will definitely give it a shot. Now is there anything bad that can happen if i dont hook the spade connectors up correctly, or is it pretty much idiot proof?
Old Jan 31, 2009
kcari's Avatar
nothing bad - just the sound quality will suck and you will know that something is wrong. When I did it, I actually cut the harness - stripped the wires and attatched the bare wire to the prongs -bad idea - I redid this and hooked connectors (to extend the oem wires) and then connecting that to female connectors and then to the male speaker prongs. Just remember which color harnes wire is + and negative
and you'll be fine. I think wiring the speakers should be the least of your worries!
and remember to remove ur 3rd brake light - don't brake it like me!
i would also suggest that you do this on a cooler day and that you give yourself enough space to remove all the paneling and seat cushions so you have more room to work. The biggest pains were popping out the white clips from underneath the dash and removing the nut that held the speaker down that was the closes to the mirror.
Old Jan 31, 2009
kcari's Avatar
Jeffdp
Aug 5, 2015 11:38 AM
Galvezj11
Jun 17, 2015 04:13 PM
Thees1
Apr 14, 2015 08:23 AM
PimpBot5000
Nov 26, 2001 07:15 PM
BabyLX
Nov 16, 2001 05:53 PM
