Interior Post your questions about interior parts here! Seats, consoles, etc
Map light not activating with door open
Old Dec 27, 2021
overheadcam's Avatar
overheadcam is an unknown quantity at this point
Need help with a 2021 Honda Civic LX Sedan;
1) Map light does not come on when drivers door is opened but did originally. All other doors do not operate the map light when opened as well.
2) Map light panel does not have the ON-DOOR-OFF sliding switch. Individual map lights will work when pushed on. Map light panel appears to have a sensor with a small hole in it.
3) All door switches appear ok.
4) Interior light dimmer setting at 15 seconds but no further settings found for door opening.
Last edited by sdaidoji; Dec 28, 2021 at 07:11 AM. Reason: don't delete just because it solved for you.
Old Dec 27, 2021
Re: Map light not activating with door open
It's normal. If you would like them to come on with the dome light, you have to run a wire across the headliner.
DIY: Map light on with Dome Light in "Door" mode
gina
Electrical
16
Oct 3, 2022 09:36 PM
leftylouie
Nov 2, 2014 09:44 AM
angelmar06
Feb 1, 2012 12:23 PM
stratos285
Dec 9, 2004 08:42 PM
Huh_Oh Sh*t!
Jul 8, 2003 02:13 PM
