Electrical Post your Electrical issues here!
18 civic si tail lights [solved]
Old Feb 2, 2024
Hondaprowler's Avatar
Hondaprowler is an unknown quantity at this point
So I’m having an issue with my tail lights. All other lights work. Break, turn signals and backup are all good but both taillights aren’t working and I believe the light on the trunk, the long light is a tail light as well that’s not working. So I doubt both or all three crapped out at once. I’ve replaced fuses 9,13,18 under the hood and I believe 22 under the dash with no such luck. Possibly the relay or a fuse I’m missing? Any thoughts on this matter would be great and I will absolutely reply with the fix once it happens. Thanks all!
Old Feb 4, 2024
re: 18 civic si tail lights [solved]
Fix- so I have a crack and water in my long trunk tail light. I’m guessing it’s shorting things out so I’ll replace that. I re replaced fuse 13 under hood after unplugging white clip in trunk leading to this trunk tail light and all other tail lights are now working. Hope this helps someone in the future.
Old Feb 4, 2024
Colin42's Avatar
Glad you figured it out
05EXSE
Mar 17, 2012 07:09 PM
crispy_666
Apr 17, 2011 03:39 PM
beanrick
May 26, 2010 04:56 PM
Civic_Racer9
South Cali
24
Jun 7, 2008 08:45 PM
TeRRoRiFiC35
Jun 8, 2005 10:06 PM
