2000 Civic: front side marker lights, tail lights and licence plate lights stuck on..
Old May 26, 2010
beanrick's Avatar
beanrick is an unknown quantity at this point
Unhappy 2000 Civic: front side marker lights, tail lights and licence plate lights stuck on..
Hello new here. Just got my Civic a week ago. Today I noticed that the parking lights and tail lights are stuck on even with the key out of the car. I tried using the search option to find a solution, but had no luck. From what i have researched I am thinking it is a relay or something.
Thanks for any help.
Old May 26, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: 2000 Civic: front side marker lights, tail lights and licence plate lights stuck
Are the brake lights on too? If not, the light switch on the steering column may be bad.
Old May 26, 2010
beanrick's Avatar
Thanks very much for the info. I will check it out. Again thanks.
Old May 26, 2010
CraigW's Avatar
Maybe the contacts on your tailight relay stuck closed, it is located in the under dash fuse box.
You could try gently tapping the relay case tops, it may drop back out.
CarStuff
Dec 6, 2020 12:52 PM
Poopies
Apr 20, 2017 11:36 PM
Flipg123
May 8, 2015 01:15 PM
shaejb15
Apr 12, 2015 11:38 AM
wawacito
Nov 5, 2001 03:32 PM
