Electrical Post your Electrical issues here!
2017 civic window problem
Old Apr 27, 2023
Sweeny11's Avatar
Sweeny11 is an unknown quantity at this point
I have a 2017 Honda civic. The driver side rear window will roll down but won’t roll up from both the driver switch and the actual door switch. If I wait 20 minutes it’ll go up inch by inch every time I wait. Seeing as it rolls down fine make me think it’s not the motor. So is my best bet to look into the door switch if so which one would be the problem the driver door or the actual door switch.
thank you
Old Apr 27, 2023
BrotatoChip's Avatar
Super Moderator
Re: 2017 civic window problem
The overload function is probably part of the motor itself, I don't have schematics to check. Is it getting pinched in the track or seal?
Old Apr 27, 2023
Sweeny11's Avatar
it doesn’t seem to be getting pinched I guess I never really looked. It seems to go down perfectly straight. And I can pull the window up by hand easily while someone else holds the up button on the switch
Old Apr 27, 2023
Colin42's Avatar
Try lubing the seals and regulator
Old Apr 27, 2023
Super Moderator
+1 from me.
Timbogates
Electrical
Mar 4, 2022 09:15 AM
keithkvh
Aug 4, 2016 07:30 PM
Dave Brabant
Sep 9, 2015 08:11 PM
mhsmom
Aug 31, 2015 10:45 PM
catdaddybaycali
Mar 4, 2015 02:18 PM
