Electrical Post your Electrical issues here!
Multiple problems after snow [solved - one more rodent chewing wires]
Old Feb 14, 2021
rrshende's Avatar
rrshende is an unknown quantity at this point
I have Honda Civic 2016 sedan. After some snow over the weekend I see multiple problems on dashboard -
1. Power steering System problem
2. Brake hold problem
3. Tire pressure monitor system problem
4. Vehicle stability problem, etc
I was able to start my car, AC/heater and wipers work. I cannot move my steering vehicle easily and therefore cannot drive.
Any suggestions on what I should do?
Top Answer
Feb 16, 2021
rrshende's Avatar
rrshende
Re: Multiple problems after snow
So the service center said the EPS SUB HARNESS (A) needs to be replaced since rodents chew it. Is it fixable at home if I buy one? They dont have the part in yet.
I found this https://www.hondafactoryparts.com/oe...IFJlc3VsdHM%3D
Old Feb 14, 2021
FRSam's Avatar
Click Here
It’s more likely due to the cold. Tire pressure will contract in cold. The power steering light has come on before on my car when it’s seriously cold out.
Old Feb 14, 2021
Colin42's Avatar
Check the battery voltage and make sure the terminals are tight
Old Feb 14, 2021
rrshende's Avatar
@Chezboat24 Thanks. So should I just wait for weather to get better? What does these 3 line mean?
'09 TSX 6-Speed
'03 ZX7R
'72 CB350 Twin
@Colin42 Thanks. I will check. What is expected voltage?
Old Feb 14, 2021
that's part of his signature. Not part of the message.
As far as battery voltage, should be ~12VDC. Make sure all battery connections are good. You may have good voltage, but if there are any loose (even slightly loose) connections, it can cause your dash to light up like a christmas tree
Old Feb 14, 2021
Colin42's Avatar
Should be 12.5v or a little higher with the car off
Old Feb 15, 2021
cold is bad for batteries, more even so with older ones
Old Feb 15, 2021
rrshende's Avatar
So I drive the vehicle for around 8 miles and checked the battery charge and it was 12V above.
I still see these errors on the dashboard
Any thing else I can try
Old Feb 15, 2021
is the steering still heavy?
also, if you have code reader, reset the codes
moving thread out of the root 10th gen and into the proper section - you have an issue, it goes into the issues section
Old Feb 15, 2021
FRSam's Avatar
Click Here
How cold out is it?
Old Feb 15, 2021
rrshende's Avatar
Yes it is heavy.
> How cold out is it?
It is 40 F
What is code reader? I might not have it.
Old Feb 15, 2021
rrshende's Avatar
Can I use this "HyperTough HT309 OBD2 Scan Diagnostic Tool Code Reader" as code reader?
https://www.walmart.com/ip/HyperToug...r-Red/54620271
Old Feb 15, 2021
choose one of these. Bluetooth are better, WIFI can screw your phone connection.
Amazon Amazon
download app torque to your phone
they might not read some honda specific codes and SRS ones, but work well for the price
Old Feb 15, 2021
FRSam's Avatar
Click Here
Okay. It has nothing to do with the cold then. Mine was occurring closer to -40F.
Old Feb 16, 2021
rrshende's Avatar
Old Feb 16, 2021
so, second rodent case in a week...
the cold actually have to do with the issue - they find warm places to stay and get under the hood. then start chewing stuff...
Old Feb 17, 2021
Aynardann's Avatar
Aynardann is an unknown quantity at this point
Re: Multiple problems after snow [solved - one more rodent chewing wires]
The little robbers ate the wires, well at least it didn't lead to anything bad, except for the Christmas tree on the panel
mhumphries77
Brakes
Dec 16, 2020 04:57 PM
Ric
Brakes
Jan 8, 2020 07:01 PM
Ric
Apr 21, 2010 12:07 PM
tl-r dude
Nov 13, 2008 07:33 AM
