Brakes Post your questions about Brakes problems here!
Parking Brake Sensor Issue
Old Nov 11, 2024
CivicJoe's Avatar
CivicJoe is an unknown quantity at this point
I have a 2021 Honda Civic sport with the manual transmission. I replaced a rear brake pad and while doing the job I mistakenly pulled the parking brake sensor wires out from inside the connector. It appears that the connector really just holds the wires in place such that each wire end goes over a peice of metal on the other side. I thought I was able to put it back together with some epoxy so everything was connected again.
Unfortunately the left parking brake still isn't engaging. But that isn't the big problem because one side is sufficient for my purposes. The problem is the error message and the beeping when I drive the car.
Two questions then:
-Any thoughts on fixing the parking brake sensor wiring connection? The white and black wires and their ends are still in good condition, just had pulled out of the connector
-Any thoughts on turning off the error code on my dash (along with the beeping)?
-Even if I did connect properly again, do I need to reset something?
Last edited by CivicJoe; Nov 13, 2024 at 05:46 PM. Reason: making description more clear
Old Nov 27, 2024
CivicJoe's Avatar
Re: Parking Brake Sensor Issue
Any ideas? How can I get the parking brake warning and beeping to go off on my dash?
Old Nov 29, 2024
Colin42's Avatar
Maybe there's a replacement connector you can buy and just splice the wires
bozo
Electrical
17
Feb 7, 2026 10:14 AM
B19uks
Brakes
Sep 25, 2024 07:22 PM
GOTSPRINGROLLS
Feb 20, 2007 01:24 PM
BigDannyCool
Brakes
Dec 22, 2006 08:56 PM
henzoketchup
Jan 10, 2005 10:51 PM
