Audio Post your questions about Audio problems here!
Volume stopped working
Old May 13, 2020
Dan Buczakowski's Avatar
Dan Buczakowski is an unknown quantity at this point
Hi everyone, new here.
I have an issue that just recently started happening. I have a 2018 Civic Si. When I start the car, the radio volume doesn't work and it says it's maxed out at 11, even though 11 is pretty low. I can't go up any higher, and when I go down, it shows it going down, but nothing is actually happening. This is the case weather I'm using Car Play or just the radio. The issue fixes itself when I get an audible alert from Waze. As soon as I get an audible alert everything goes back to normal. I'm not sure if it's just a Waze alert that fixes it or if it's any type of audible alert. This started about a month ago. Has anyone else had this problem, and if so, was there a fix for it? My car was just in for a tune up, so if there was an update for the radio I'm guessing they would have done it then. My phone and all apps are updated to the latest software.
I appreciate any help.
Old May 14, 2020
GolNat's Avatar
Prelude Owner
Re: Volume stopped working
Pull the fuse for the radio to reset it.
The radio probably has 2 separate volume controls so that when you receive a call or map direction it is at a different volume then the radio.
Old May 15, 2020
I thought that also, but when I get an alert it fixes the volume for the radio. It's a really weird bug that just started happening. I'll try the fuse idea and see if that fixes it. Thank you.
ChrisCivic97
Electrical
May 17, 2020 08:00 PM
hedeyyy
Electrical
Dec 6, 2019 06:15 AM
Chd61584
Aug 26, 2019 04:54 AM
harry456
Jun 13, 2019 12:30 PM
whitedaze
Aug 30, 2005 09:51 PM
