Replaced catalytic converter [not a problem, recommendation]
Old Aug 7, 2024
hogdaddy's Avatar
hogdaddy is an unknown quantity at this point
It was throwing the code for converter replacement on my 2019 LX sedan.
This is a simple job and it took me about an hour.
All new Honda parts.
Only somewhat difficulty was removing the bottom steel ring seal.
Spray PB Blaster on it and let it soak in.
Support the exhaust pipe underneath and from above get a hammer and small thin screwdriver.
Tap around the edge. It will dent and you will be able to pry it out in no time.
Do not attempt to clean Oxygen sensors just swap them over.
haydeon
Oct 30, 2013 04:13 PM
laack
Feb 20, 2010 11:50 AM
SOHCScreamer
Oct 9, 2002 11:40 AM
Maximus
Nov 17, 2001 07:14 PM
