Installed my Ignited Illuminated Pushbutton Ignition <phew, wipes brow>
Old May 7, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Spent the latter half of yesterday researching and finally worked up the ***** to do it last night. I installed the button just between my cruise control and power mirror controls. I had to do some dremeling to make it fit.
Wiring was pretty simple, but I really looked hard to determine which wires to tap into because I didn't wanna blow anything...I need this car to go to work! So after some (OK, a lot of) help from my BC friend Kaostik, I wired 'er up (found a decent ground, a 12V Ignition on source for both the button and the light, and the starter wire, put the key in, turned it to on, and hit the button.
NOTHING
Then I remembered that I still have to put the clutch down. Sooooooo...... down with the clutch and hit the button again.
VVVRRRROOOMMMMM!!!! Yay!!!! I'm so happy I could
Now I'm gonna replace that bulb with a bright LED one.
Old May 7, 2003
AllMotorSi's Avatar
AllMotorSi is an unknown quantity at this point
congrats, got any pics?
Old May 7, 2003
Connie's Avatar
very nice job, I want to see some pics also, I can host if you need me to conradvernon16@yahoo.com
Old May 7, 2003
TeLLy's Avatar
Comin soon - my mom left the cradle AND cable for our digi in the Philippines so I have to locate another one...but soon...yes indeed...soon...
Old May 7, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
nice nice...i was thinking about one cuz i could get them cheap at my friend's shop but i didnt know how hard was the installation but i guess now i can go to u for help if i decided to get one.
did u get it from speedbump in miss?
Old May 7, 2003
TeLLy's Avatar
Actually I didn't but I know Mike can get them fo cheapo. Install is very easy..just takes the following:
18AWG wire (ground)
12AWG wire (power and ignition)
elec tape
heat shrink
wire cutters
wire strippers
med-size philips screwdriver
#10 socket (may need extension, it's tight under the steering column)
Dremel and krazy glue (depending where you mount)
Lemme know if you need more info.
Old May 8, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
Good work Telly.... definitely, definitely post the pics!
Congrats!
Old May 8, 2003
TeLLy's Avatar
Thx...gonna take pix tonite.
jzhartman
22
Jul 23, 2015 10:42 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
