tire size
Old May 4, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
tire size
anybody here have this setup?
car lowered 1.3" or more
17" rims
215/45/17 tires
and if so any problems rubbing the tires?
i have posted this on wheels section but no reply
pls lemme know, this is kinda urgent
Old May 4, 2003
GaGu's Avatar
GaGu is an unknown quantity at this point
i dont think u will rub.....i have 205/45/17 & it looks like there is room for 215/45/17
remember, i have the same springs as you!
oh yeah, whut rimz did u get?
Old May 4, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I have neuspeed race springs and 215/40/17 tires and my rear was rubbing after I corrected the camber on the back I had to roll the fenders
Old May 4, 2003
GaGu's Avatar
oh yeah, gotta watch out for that!!!
in my car, when people sit in da back the car drops like
another half inch or more....its close but nothing rubbing!!!
Old May 4, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
TTCivic has H&R sports with 205/40R17 and didnt rub now
he used to be running 215/45R17 last summer and dont think it rub but he got new tires and new size cuz he wants to try different setup
Old May 4, 2003
thanx for the info!! im going 215/45 than, want wider and thicker tire to protect my rim, got black racing pro n1
Old May 4, 2003
DragonAce's Avatar
DragonAce is an unknown quantity at this point
what's the off-set??
it'll be the factor..
i've got about a 2" drop on the rear, same size tire, 32 offset and i can't fit a finger between the tire and fender..
a 45 offset would carry the tire inward i believe so you'll have more room..
a camber kit could **** ya up tho..carries the top of the tire outward
Old May 4, 2003
ive got 45 offset, is that good or bad?
Old May 4, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
****. My Sportline is even lower, and I have camber kit, so I will have to go 205/45R17 then...
Old May 4, 2003
HIGHLYreflective's Avatar
HIGHLYreflective is an unknown quantity at this point
those 17's are going to look like 15's or 16's.
that particular rim already looks small with a 40 profile tire so they are going to look even smaller with a 45 profile.
i actually had brand new 17" ADR's for sale a few months back that looked similar to those rims for $1200 w/tires.
Old May 4, 2003
DragonAce's Avatar
probably 205/40 pal..pull it in a little and down a little as well..??
215 and 205 is only half a centimeter difference on each side..
tho if you have a 45 offset too then you might be okay..(as described below)
macro..ya, 45 is a better offset for civics..the tire is centered closer to the car
Old May 4, 2003
nice, thanks for the help!!
Old May 5, 2003
Narc's Avatar
Narc is an unknown quantity at this point
Can't see it being a problem. I have 17" rims with 205/40's on them. Lowered car by 1.4 inch and have not rubbed at all. This weekend i had myself and 3 big guys in the car. Total occupant weight around 850 lbs. Took a corner like a mad man and still no rub. In the winter, I have blizzak tires on stock rims. now that comes close, but still no rub.
Have no fear. Though I strongly recomend adjusting camber on at least the front tires. On 7th gen civics, should only cost around$120-150 with labour.
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
