attn: ppl with injen rd cai
Old Apr 14, 2003
supYO's Avatar
supYO is an unknown quantity at this point
i took my bumper off today to reseal my projectors and install a front lip so i took a look around the filter for the cai.
i always wondered what was causing this small rattle noise when im near redline and its the pipe nearest to the frame before the filter. its been contacting so much that theres a gash on the intake pipe. it didnt go all the way through but its a deep deep scratch.
have u guys taken a look at your filter lately?
i had to adjust it abit, relocated the whole cai a couple mm's and theres good clearance now
just wanted to let u guys know. for those who got it the same time as me that maybe it was installed a bit too close to the frame.
Old Apr 14, 2003
rice4foo's Avatar
rice4foo is an unknown quantity at this point
hmm...mine makes a small rattling noise when its near 1500 rpm...but it goes away as the rpm goes up...dunno how to fix it tho...
Old Apr 14, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
no way to fix it, it hits a lot of things. THe only way is find all the points it contacts something and wrap rubber or insulating foam around it... Which would look ghetto.
Just tighten the hell out of it every once in a while (when you clean filter)... Supyo did you cut anything installing the CAI or did you just squeeze it through?
Old Apr 14, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
yea i did the same, unless you cut away at the metal wall, i just wrapped it with bubble wrap, not sure how it is now
Old Apr 14, 2003
BJAI's Avatar
BJAI is an unknown quantity at this point
mine has rattling too.....
Old Apr 14, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
Maybe make your own bracket? If you need help, ask friends for creativity skill. Hell I can make it in 5 minutes lol.
Old Apr 14, 2003
nme3's Avatar
JDM wannabe
yah i got a small gash where the intake is touching the battery. heh i check it like every weekend cause that vibration scares me, like its going to just fall off or something.
Old Apr 15, 2003
BIG's Avatar
BIG
Mine rattles at lower RPM too, but I think its because its super tight against my front bumper
Old Apr 15, 2003
TeLLy's Avatar
Yes, it's an Acura EL
My injen came with a little piece of rubber to stick between any contact points. I bought some thick-*** rad tube from Crappy Tire and stuck that in there as well. Still holdin strong, no gashes or holes!
Old Apr 20, 2003
CUE2k1's Avatar
CUE2k1 is an unknown quantity at this point
I just realized I had the same problem too... GRRRR!!! I tried re-adjusting it but still same prob! The rubber piece that I put on there fell off.... NOTHING is working for me!! hehehe
Old Apr 20, 2003
1llmatic's Avatar
1llmatic will become famous soon enough
bubble wrap works.
Old Apr 20, 2003
GuSTo's Avatar
GuSTo is an unknown quantity at this point
ha, i don't even have an intake!
Old Apr 20, 2003
BJAI's Avatar
there's a good way the rattling will be gone..
this is what i really did..
make it to short ram..ahhahahahha
Old Apr 21, 2003
supYO's Avatar
my rattle is gone now
im so happy.
Old Apr 21, 2003
Dartheo's Avatar
SLIPSTREAM R
Dartheo is an unknown quantity at this point
I had this problem before... i posted it in the GTA i think... either way...
It would make the noise around 5.5 RPM
Mine was knocking against a bracket so i just took out the intake and put a **** load of duct tape around it where it was making contact... then used some zip ties to fasten it to the bracket so that it wouldn't rattle... it worked for a while but then my intake is just fuked and the filter doesn't fit properly so i took it off... haha
Old Apr 21, 2003
Chigga's Avatar
Chigga is an unknown quantity at this point
how do you guys like you injen CAI????
im thinking of buying one!
how hard is the install???
later??
any hole drilling for the piping?
Old Apr 21, 2003
nme3's Avatar
JDM wannabe
instal isnt that hard actually. taking out the stock air box is what took me the longest, probably around 3 hours altogether for me and i havent even touched anything to do with cars before this. all you need is a 8mm, 10mm, 12mm socket, and a normal screw driver. oh yah and an extension. as for drilling most people said you gotta cut the fender wall for the piping to fit but i was able to just squeeze it through without any trouble but you gotta take off your front bumper.
Wariogamer
Sep 29, 2015 09:49 AM
vino
Jan 28, 2002 09:09 PM
mohawkboom
Jan 18, 2002 08:36 PM
vino
Dec 15, 2001 07:59 PM
trevor
Nov 16, 2001 05:02 PM
