Shift-Knob Replacement Question
Shift-**** Replacement Question
i just bought a new 5ZR shiftknob to replace my wack *** stock one...but when i tried replacin' it...the silver ring was in the way...and not like da factory ones...the silver ring doesn't clip on my new shift ****...and looks kinda wakk because theres a space between the ring and da ****...juss wonderin...wat should i doo??...juss holla at me yooo
do what 99% of other people do including me.. put a little electrical tap around the shaft of the shifter rod and pull up the factory ring. so the friction from the tape holds it up.. not enough tape it comes down easy...too much tape.. can't but the original shifter ring over..[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Quote
[hr]Originally posted by: DonDada
i just bought a new 5ZR shiftknob to replace my wack *** stock one...but when i tried replacin' it...the silver ring was in the way...and not like da factory ones...the silver ring doesn't clip on my new shift ****...and looks kinda wakk because theres a space between the ring and da ****...juss wonderin...wat should i doo??...juss holla at me yooo[hr]
I did mine the BEST way. I didn't use a tape since i don't want it to be sticky...
Get a very THICK elastic band. Wrap it around. It may be a bit loose but just run the entire silver ring over it.
the ring will stay up there pretty welll.
yah i thought 'bout tryin the electrical tape...but im scared it might look kinda ghetto though...as for the elastic band...i dont really undastand it..so lemme knoww
Quote
yah i thought 'bout tryin the electrical tape...but im scared it might look kinda ghetto though...as for the elastic band...i dont really undastand it..so lemme knoww[hr]
Use a thick elastic band to make the diameter of the shift **** thicker.
(imagine wrapping a elastic band around a pencil until you can no longer wrap it)
it'll create a small bump. Pull the ring to run over this bump and the friction will keep it from falling.
Hard to describe but very easy to do. give it a try. i'll take pics with a mock set up if u still have trouble.
Back from the dead
Quote
[hr]Originally posted by: riceboi
anywhere that sells shift *****, should sell the ring too.
both are momo[hr]
both are momo[hr]
oneheadlight
Apr 29, 2015 11:30 PM
thesushiboy
Apr 12, 2015 02:54 AM
Looks good that way
