RSX sway bar fitting
Old Nov 28, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
Also tried to put on RSX sway bar today, but found the bar to be quite different orientation... When mounted, the original sway bar seems to have a notch that /---------\ goes like that, whereas the RSX sway bar looks like it will sit perpenticular to the chasis... Hmmmmmm.... Sounds confusing. But anyone can enlighten me (if you've already had yours converted) how the fitment is like?
Old Nov 28, 2002
cosmicjim's Avatar
cosmicjim is an unknown quantity at this point
it should fit perfectly ... remember the bar isn't symetrical ... if you dont get it in the right orientation, the bar will hit something ... other than that, it should fit fine
Old Nov 28, 2002
2K1SiCDN's Avatar
2K1SiCDN is an unknown quantity at this point
I've had it installed on my car and you can install it upside if you're not careful, it's the exact shape as our's but thicker, if you're unsure check another civic for reference. I think they had a thread in suspension or parts forum a while back.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
muniorbust
33
Aug 31, 2015 08:59 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
