Aluminum Shifter Assembly Bushings...
One of few in the 13's
I was wondering if anybody else wanted to order this... because it's not worth shipping something at $8.50.
Here's the info... I need 3 more people...
-Aluminum Shifter Assembly Bushings
for 2001-2003 Honda Civic manual transmissions
Improve your shifting with a more precise and solid feel.
Because the stock shifter assembly uses rubber bushings, during hard shifts, (such as from 2nd to 3rd) may result in "shifting" the entire shifter assembly too! Wasted motion occurs, and a lose shifting feeling occurs.
Replacing the stock rubber bushing with these light weight yet high strength aluminum bushings will ensure that the shifter assembly is attached firmly to the body chassis, resulting in a more precise and solid shifting feel.
They are custom manufactured by an ISO 9001 certified hardware company, so you can be sure that these bushings are of quality and made within the precise specified required measurements to ensure a perfect fit.
They come with easy to install pictured instructions. Average installation time will take half an hour with simple tools.
These bushings fit on 2001-2003 Honda Civic, manual transmission, all trims except for Si/SiR
The bushings will also fit 03 Honda Civic, but the instruction isn't formatted for the 03s since the 03 civics have different center console. They are very similiar though, and following the instruction, you should be able to figure out how to remove the center console easily.
POST IF YOU WANT IN! THANKS!
It's $8.50 US Funds but they wrote that the maximum (Quantity) for shipping is 4 sets. But I'll call them maybe we can have a group buy?... Dragon Ace i'll call them on Monday.[IMG]i/expressions/beer_yum.gif[/IMG]
I am pretty sure that's what they mean, because are SIR is the Si in the states. I will call tomorrow to answer all your questions. But I'm pretty sure that are (SI and Lx) tranny's are the same (Just the differance in gearing). I am calling tomorrow.
velozp
Dec 13, 2015 11:28 AM
ThatGuy913
Sep 28, 2015 05:35 PM
