THE CREAKING OH GOD MAKE IT STOP!!
Old Jul 30, 2002
brodie_rider's Avatar
brodie_rider is an unknown quantity at this point
Hey guys, as the thread says, this problem is annoying. I installed a camber kit front and rear on saturday and since then the alignment is a lot better after lowering the car. BUT the rear struts or pivots or whatever is creaking ALL the time. It's especially noisy when I go over bumps. Weird thing is the fronts do not squeak or creak whatsoever. I greased the nuts and bushings of the rear swaybar, and the linkage plates of the camber kit using a high pressure aerosol automotive grease I bought from Canadian Tire. It still creaks and squeaks etc.
I'm asking any of you who has installed a camber kit all around or rear only have the same problems? This is really bothering me and any input would be greatly appreciated guys and gals[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jul 30, 2002
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
hmm it's funny same thing happened to my car when i got new 17 wheels... but lessened dramatically after i lowered it 1 inch.. weird!
Old Jul 30, 2002
newkid's Avatar
newkid is an unknown quantity at this point
could be the progressive part of your rear springs...they would make a sound when u go over bumps when they hit each other...
so if that is ur problem u can fix it by wrapping the springs with rubber from the oem springs
Old Jul 30, 2002
GuSTo's Avatar
GuSTo is an unknown quantity at this point
did you get rubber or plastic bushings on the camber kit?
a lot of people get the squeeking from the plastic, because they aren't greased enough...
where did you get the camber kit and how much??
i need one in the rear!!
Old Jul 30, 2002
i got the camber kit from speedtech for $380 install included. this is the ingalls. no, no rubber or plastic bushings.
Old Jul 30, 2002
draven's Avatar
draven is an unknown quantity at this point
WD40 on the entire spring/strut assembly..? just reach behind the wheel and apply like crazy... works for some people...
Old Jul 30, 2002
GuSTo's Avatar
hmm....
i guess you missed my GB post a few weeks ago...
i had them for $240 for just the rears...
we still need two more for that GB
Old Jul 30, 2002
mine was $380 for front and rears including install
draven: isn't wd40 a degreaser? it wont stay on for long compared to grease right? i dunno.
where can i get those rubber boot things for the springs? are they hard to get installed and how much are they?
Old Jul 30, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
When mine were done they just pulled rubber tubbing of some sort over the springs. Home Depot man.
Old Jul 30, 2002
how should i install the rubber stuff around my springs since they're already installed? any ideas?
Old Jul 30, 2002
MSoft's Avatar
Of course you'll have to take off the springs to do it that way... Otherwise, WD40 spray away, baby. Of course, if you can find spray grease, that'll work.
Old Jul 30, 2002
ok, thanks a lot for all the help, everyone. I am going to try what MSoft recommended. I do have spray grease, so I will try spraying it on the springs... hopefully that should help.
Again, Thanks! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jul 30, 2002
GuSTo's Avatar
hey msoft...where did you get yours?
seeing if i can find somewhere that can beat the price i've been quoted
Old Jul 30, 2002
Gusto: I got the rear Ingalls for $240 without a GB... at Speedtech
amrhamed
Aug 31, 2015 07:47 PM
crowtoo
May 11, 2015 06:50 PM
Thees1
Apr 14, 2015 08:23 AM
tattedlariat
Apr 12, 2015 07:55 PM
sonsonzai
Nov 4, 2001 12:52 PM
