2004/05 taillight conversion
Old May 16, 2006
jer2k's Avatar
jer2k is an unknown quantity at this point
Who in canada has done this...
I tried to go get the Adaptaplug as seen in the diy: http://www.7thgencivic.com/forums/sh...d.php?t=158488
but I cant get it in Canada. So if you did this what did you use to get the top bulb in the 2004 tails?
Old May 17, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Why not go to a junker and clip them off a wrecked 04/05 coupe, then splice and solder in?
Old May 17, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Wow, sucks that it isnt a straight plug in for the coupe... I just did a 03+ JDM Tail conversion on my sedan and it was pure plug and play.
Old May 17, 2006
Karumba's Avatar
Boredom causes changes ;)
Andrew (Si2NV) and Erik (DnarahP) in Ottawa have to my knowledge.. believe one just forced the bulbs in
Old May 17, 2006
jer2k's Avatar
hmm forced them in eh....well that would definatley require some shaving of the tails and I cant do that....
Old May 18, 2006
EŽik's Avatar
Actually I had the wire adapters WITH the lights. All that needed to be done was some quick soldering and voila. One of the wires you don't use (off the '01 tails) Viper did the conversion for me. If you have a set he can walk you through it. It took a whole 30 minutes to install them.
Karim, no forcing required. I know Norek actually did his '05 tail himself. He rewired his '01's. basically a "ghetto" version of the '05 tails.
Old May 18, 2006
Karumba's Avatar
Ah no wait.. it was forced in / ghetto with the brake/turn being in different locations right???
Bah, in any event, I don't have to worry about it because I'm not a coupe
Old May 19, 2006
EŽik's Avatar
Well nothing was forced in b/c the wiring I have is FOR '05 tail lights. so they were plug and play (after they were soldered into place)
Old May 19, 2006
Karumba's Avatar
Think we are talking about two different things now... or maybe wasn't even you but Andrew instead. Or maybe it was with his old tails.. didn't at one point one of you guys switch where the lights light up (brake area became turn signal, turn signal became brake area) ?? And it was done by "forcing" the bulbs in..
But like I mentioned - not concerning this, doesn't exactly concern me .. so good luck with the new mods
Old May 23, 2006
EŽik's Avatar
That was Norek.
Old May 23, 2006
jer2k's Avatar
I have ordered the socket thats necessarty from honda. I will have to force the 02 wiring into the new socket.
Old May 26, 2006
jer2k's Avatar
The lights are in....ordered 33304-S30-003 sockets from Honda and 7443 bulbs (even though its says 7440 bulbs) and haved the socket and 02 plug to fit. Everything is tight and snug and it looks good.
Old May 26, 2006
GuSTo's Avatar
GuSTo is an unknown quantity at this point
i don't remember exactly, i think i just spliced some wires
Old May 27, 2006
EŽik's Avatar
Thats what I though I did as well. Maybe we did it wrong? hehehe
Old May 27, 2006
jer2k's Avatar
I always do things the most expensive way possible
Old May 28, 2006
EŽik's Avatar
^ At least you get a warranty with those things though. And peace of mind your not getting screwed.... well most of the time. Post pics when you get a chance Jeremy
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
SoNiCcIvIc
Mar 25, 2002 08:51 AM
