4bolt to 5bolt conversion questions...
Old May 28, 2006
AznSaint's Avatar
AznSaint is an unknown quantity at this point
im thinking about converting to the rsx 5bolt conversion... does anybody know if the rear control arms are a direct swap? the front as well...? or if modifications are needed to do the conversion?
another question is... if im to convert to 5bolt, does that mean i would have to switch to the rsx shocks/springs (suspension) set up as well?
if i dont do a k20 (type S engine) swap... then i would need custom axles...? can anyone comfirm that?
if i DO the type S engine swap... then i dont need custom axles?
Old May 28, 2006
DaMDaM's Avatar
DaMDaM is an unknown quantity at this point
u can pm BattleEndless they should be able to help u out......their civic has a rsx 5 bolt conversion
Old May 28, 2006
BattleEndless's Avatar
BattleEndless is an unknown quantity at this point
Thanks Damdam .. pm'ed you Aznsaint
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
18
Aug 4, 2021 01:28 PM
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
