HID questions!
Old Apr 4, 2005
ViEtDraGoN's Avatar
ViEtDraGoN is an unknown quantity at this point
HID questions!
i'm seriously thinkin about buying a set of HIDs for my car.
and for all those who have HIDS and tips or advice.
can anyone help me out with the questions below! thanx!
1. Should I Get HIDs for my blacked out or For Projector lights?
(problem being i like the projector look but i can only use it for summer cuz in the winter it fogs real easy... a big **** off to be honest, and also a lil paranoid about burning throu the plastic of the stock lights)
2. I want the blue colored HIDs does anyone know what number that is?
(ex. 4000k, 5000k, 65000k, etc..)
3. wheres a good place to get them?
4. Prices, i juss wanna know a range of how much i might be spending.
5. And are they easy to install?
Thanx Guys n' Gals!
Old Apr 4, 2005
phuviano's Avatar
Slowest 7thgen in the GTA
1) I heard that projectors are the worst headlight housing you can use for hid's, unless they are real hid projectors.
2) The higher the kelvin temp, the more blue or even purple the lighting will be. 6500k will put out the most blue light. I'd stick with 4300k or 5000k max just so cops stay off your butt. 4300k will be brighter than 6500k though.
3) you can get them pretty much any where, but if I were you, I would buy the phillips , osram, or hella brand ballast. Everything else is crap, especially mcculloch, brightstar, and those other crap brands. Those brands may be cheaper, but remember, you get what you pay for.
4) as far as I know, I've seen hid's go for $350 to around $600 cdn, depending on your light bulb, and kelvin temp you want.
5) easy to install?? its a piece of cake. Its pretty much a plug and play.
Old Apr 4, 2005
ViEtDraGoN's Avatar
hehe answered every question, thanx man!
Old Apr 4, 2005
ViEtDraGoN's Avatar
well as far as my projectors i'm planning on getting TYC projector head lights... will that be ok?
Old Apr 4, 2005
phuviano's Avatar
Your better off using hid's in your stock headlights. You'll get more light output from you stock ones. I've heard a lot of complaints that hid's are not good in TYC headlights.
Old Apr 4, 2005
stock housing, 4-5k color is brightest, Impulse sells xtec kits. Price $200-500. Hid burns alot cooler than halogen so no worries about melting.
Old Apr 4, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Try reading up on it on this site.. there are a lot of members that have tried many different headlights for their HIDs
There is a 7thgen on my street that is using projectors with HIDs and its pleny bright but not as bright as other setups
Old Apr 5, 2005
ViEtDraGoN's Avatar
thanx guys for the input! brightness i'm definitly lookin for and blue... so which one should i get as far as the numbers go... 4000k? 6500k? and which companies would u guys recommend?
Old Apr 5, 2005
1llmatic's Avatar
1llmatic will become famous soon enough
6000k is blue enough.
you will most likely get pulled over.
Anything higher and you will get pulled over. no question.
Old Apr 5, 2005
TeLLy's Avatar
Yes, it's an Acura EL
I've been pulled over a few times for my 6500K. Never ticketed though, just harrassment and warnings.
Old Apr 5, 2005
ViEtDraGoN's Avatar
telly u have 6500k? what company are they? and how much did u get them? and are they bright?
Old Apr 5, 2005
TeLLy's Avatar
Brightstars, 400-ish, plenty bright but the lower temps light up more stuff on the road, like around 4000-4300K.
Old Apr 23, 2005
ViEtDraGoN's Avatar
can someon explain is it easy to install my HIDS in to halo projectors? cuz right now my HIDs are on my stock lights, and i know i would need to buy a new set of h1 bulbs for the projectors but is it juss as easy to install as on my stock lights? cuz i read some threads about "retro fitting" and i dont know what that is... thanx!
Old Apr 23, 2005
ImPulse's Avatar
Thanx Guys n' Gals!
1) Since you like projectors, then go get an HID kit that will work with your projectors, and silicone them up so that they dont fog anymore
2) 4500k = white, 5000k = white/aqua, 6000k = white/violet
3) I can get them for you if u are interested
4) Typical kit goes over $300 (not talking about crap ebay kits)
5) Yes, well, the ones I sell are simply plug and play
Old Apr 23, 2005
ImPulse's Avatar
most kits out there require you to drill a hole into the back of the projector/bulb opening so that the bulb will fit. The kit that I sell is a direct plug in and wont require drilling. The HID kit you have in your stock headlights will not work with your projectors cause you need different size bulbs.
Retrofitting has nothing to do with what you want
http://www.7thgencivic.com/forums/sh...d.php?t=194211
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
