which is better
Old Jan 18, 2005
linsook's Avatar
linsook is an unknown quantity at this point
which is better
i need new rotors. so is slotted rotors better then the ones with the drilled holes???? i also need ur opinion on brakes pad and places where i can get it for cheap need it asap
Old Jan 18, 2005
BIG's Avatar
BIG
slotted
Old Jan 18, 2005
Pharoh's Avatar
Bobaganoosh!
KVR for everything
Old Jan 18, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Drilled ones are more in danger of cracking. Slotted ones have a reputation for chewing up pads faster, but at least they won't crack.
Old Jan 18, 2005
linsook's Avatar
do u guys know how much they usually go for(slotted rotors)
Old Jan 18, 2005
1llmatic's Avatar
1llmatic will become famous soon enough
depends on the quality of the rotor.
the nickel cadium coated rotors are expensive but will never rust.
Old Jan 18, 2005
R1Style's Avatar
Actually... crossdrilled rotors used to crack. New technology and better quality crossed-drilled rotors are in no danger of cracking more so then blank rotors now adays.
Old crossdrilled rotors used to be drilled in random spots. New crossdrilled rotors are drilled in a specific pattern to achieve optimal cooling/venting and prevent cracking.
Example of some high quality crossdrilled/slotted rotors:
RacingBrake Rotors
Brembo Crossdrilled/Star slotted Rotors
Edit:
As for Brake Pads... I'm using the EBC Greenstuff and I hate them. They create way to much brake dust and are squeeky as hell.... although they do provide nice stopping force with minimal pedal pressure.
I would higly recommend you go with Williams Pads. They are supposed to be awesome. These are what I plan on getting next... remember to get the ones for Street/autcross/solo2 (WPFS2).
Link to the site
Or you can also order them from Wheel and Tire Zone in Mississauga
