H22 B18c ??
Old Jul 12, 2004
biff's Avatar
biff is an unknown quantity at this point
H22 B18c ??
Has anyone heard of an H22 or B18C swap into a 7thGen? I know of a shop that said they would make it fit... might be an idea as K20's arent worth the bucks at the moment... any thoughts? anyone done this? any motor mounts avail for these swaps??
Old Jul 12, 2004
vicLX's Avatar
<--That really is ME
it'll fit but you cant put an older engine in a car... the engine has to be newer than the car....
Old Jul 12, 2004
Booohahaha's Avatar
BAD MON
sure if u like the idea that u have to push the firewall on ur cockpit a few inches back and have no front subframe
Old Jul 12, 2004
biff's Avatar
just curious, theres a shop in toronto that says that they can fit an H22a in my car if i wanted as the K20's where pricey... i figured someone might have done this already
Old Jul 13, 2004
RIC3BOY's Avatar
RIC3BOY is an unknown quantity at this point
Any B series motors should fit, don't they have the same mounting points as the D series motors? But anyway, I'm not too sure about the H22. Technically, any shop can "make it fit" haha. And even though the idea of a H22 would be really nice, if you're planning on getting a K20 swap sometime in the future I think it would be best just to save up for it, or just pickup a B18 or something. But then again, why would you go for an older motor? Good luck!
Old Jul 14, 2004
Touge_Motors's Avatar
Touge_Motors is an unknown quantity at this point
Nobody has done it... Why? Cause:
-H22's are heavy lugs of crap!
-they respond poorly to mods
-and are poorly designed
-PLUS i dont think you come CLOSE to realize how much work it is to put an H22 in a 7th gen... Just go K...
All motor doesnt pay unless you go K!
Old Jul 14, 2004
solo_rider's Avatar
solo_rider is an unknown quantity at this point
doesnt hasport make motor mounts for a b16 swap in our cars. so if i'm not mistaking you can put a earilier model engine in a later model car.
Old Jul 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I don't think they make such a set. At least not from reading the Swap Combinations section of their site.
Old Jul 15, 2004
R1Style's Avatar
No Hasport does not make B series motor mount kits for our car.
The fact of the matter is, you can't put an older engine in a newer car. The engine has to be available the same year the car was built. End of story.
Old Jul 15, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
^^^^^^ does that go for canada too? they don't have emissons, do they?
Old Jul 15, 2004
HyaBoosta's Avatar
There is one member on the boards that is swaping a built B16 into a 7thgen but it's only for the track. seach the boards and you'll find it
Old Jul 15, 2004
solo_rider's Avatar
if ya'll wanna get technical about i have heard of an h22 swap into a 7th gen! AEM's yellow front wheel drive 7th gen grag car has a turbo charged h22 powering it. it stats: 2001 civic best et 8.12 qt weight 1,650 engine: 2.2l h22 prelude engine, engine management: motec m48 pro, 800 and up hp
Old Jul 15, 2004
TeLLy's Avatar
Yes, but it's a drag car, which means the whole chassis was stripped down so basically the only 7thgen components left were the basic body style and maybe some pieces of frame. Also it no longer needs to conform to any kind of street/highway laws. That's like saying "I've heard of someone putting a jet engine into a mustang". How much of the original car is left?
Old Jul 15, 2004
HyaBoosta's Avatar
word to your mother!
Old Jul 15, 2004
TeLLy's Avatar
And to yours, HyaBoosta.
Old Jul 15, 2004
HyaBoosta's Avatar
Thanks!how polite
Old Jul 15, 2004
You also forgot to mention it RWD you idiot! dont get in the ring with Ali if you cant box ****...
Old Jul 15, 2004
biff's Avatar
Hasport is making mounts for B series... go to the swaps section theres a dood on there from Hasport that talks about them in progress...
Old Jul 15, 2004
seriously dude it's totally not worth it...
Old Jul 15, 2004
TeLLy's Avatar
Word to your mother, Touge.
Old Jul 15, 2004
biff's Avatar
I never said i was going to get it..
Old Jul 16, 2004
HyaBoosta's Avatar
if hasport made mount i would consider it cause it's alot cheaper than k20
Old Jul 17, 2004
Not really... what will you use for a wiring harness? OBD2 first gen to OBD2 second gen... I dont think so! You guys arent listening H22's are heavy and respond poorly to mods...
ttamrekab
Sep 28, 2015 01:22 AM
anubis62
Sep 27, 2015 12:56 AM
ttamrekab
Sep 25, 2015 04:41 PM
NROD315
Sep 12, 2015 02:46 PM
NROD315
Sep 4, 2015 09:22 PM
