brakes sqeaking.............?
Old Jun 21, 2004
AznSaint's Avatar
AznSaint is an unknown quantity at this point
just recently... i'd say about two weeks ago. i noticed my brakes started to squeak.. whether it's slow braking or hard braking.
i have recently just put on smaller rims/tires on.... and im wondering if that could be a reason for it to start squeaking??
205/50/15... compared to the stock 185/65/15
i have aftermarket Slotted rotors w/aem brake pads.
another scenario could be that,......... i was at shannonville about three weeks ago or so... and i did work my brakes really hard... and wondering if that could be a cause for my brakes to squeak?
i guess, my main question is, what causes brakes to start squeaking????
is it b/c something is loose?
thanks.
Old Jun 21, 2004
AznSaint's Avatar
or do i just need to lubricate something under there?
Old Jun 21, 2004
Booohahaha's Avatar
BAD MON
i got that too.. immah get it cleaned up and lubricated soon though
Old Jun 21, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
just get them serviced, that should take the sqeaking away.
Old Jun 21, 2004
Booohahaha's Avatar
BAD MON
smoked... remeber u said there was a clicking noise.. haha.. it wasnt my tranny or gears.. it was the breaks..
Old Jun 21, 2004
vicLX's Avatar
<--That really is ME
take it apart, clean it then pop 'em back on... maybe a tiny rock got cought
Old Jun 21, 2004
AznSaint's Avatar
i figured my brake pads were waring down...
id ont have money to get it serviced...
are there any specific reasons that would actually cause it to start sqeaking?
Old Jun 21, 2004
Booohahaha's Avatar
BAD MON
ehhh.. let me see..
stop booting it to impress the gals at the bus stop.. come on u know wut im talking about
Old Jun 22, 2004
AznSaint's Avatar
hahaha... fine fine, you figured me out boo....... but i cant help it. hahaha
Old Jun 23, 2004
iamfob's Avatar
iamfob is an unknown quantity at this point
probably nothing serious
dont worry
Old Jun 23, 2004
SiRB16's Avatar
SiRB16 is an unknown quantity at this point
some (not all) hi-performance brakes will squeak like a TTC bus. I know because I have Hawk HP Plus and they squeak, but I don't really care cuz dayam....I can stop on a dime....
but some times they just need a bit of cleaning ....
nothing is loose....
Old Jun 23, 2004
AznSaint's Avatar
thanks.
b/c they never squeaked before....
i just noticed it recently... so i was just wondering if it was from my extensive use of the brakes at the track or just b/c i put small rims/tires on........ or neither.
where would i look for if i wanted to do a lil' cleaning?
thanks.
Old Jun 23, 2004
jongreenway's Avatar
jongreenway is an unknown quantity at this point
Brakes squeak all the time. Apparently my brakes were serviced in April (so Honda says), and they squeal every now and then right now. It's not a problem as long as they don't squeak EVERY time you brake.
Also, if it only squeaks when you first start up the car and start driving, then it's not a problem either.
Old Jun 23, 2004
AznSaint's Avatar
it squeaks when i brake.
Old Jun 28, 2004
Dartheo's Avatar
SLIPSTREAM R
Dartheo is an unknown quantity at this point
is it when u just start driving or is it constantly?
Old Jun 28, 2004
UPDATE - So I started to get a rattling sound coming from my brakes. Turns out the front brake pads are worn out and need to be replaced. So squeaking is maybe an indicator that the pads are wearing down aswell?
ALSO, my front pads are now gone, after only 58,500 kilometers. Is this rare? How long before your front brake pads were replaced?
Old Jun 29, 2004
AznSaint's Avatar
i dont hear it no more.. but i hear it off and on.
but it has only started recently.. like in the past two, three weeks
i've never heard squeaking in the past two years... or the past three months since i put in aem brake pads
Old Jun 29, 2004
phil79's Avatar
phil79 is an unknown quantity at this point
hey my car a civic 2001, and when i brake not even that hard, my car makes a sqeaky noise (kinda like the sound of a car with bald tires making a sharp turn.) but it sounds like its in the rear what do you guys think? i just got my tires off the front and my front breaks looks like they are pretty good still. so i don't know whats wrong. you guys have any solutions?
Old Jun 29, 2004
AznSaint's Avatar
not possible for brakes to squeak in the rear.. b/c we have no brakes in the rear.
only drums.
unless you have 1.7el
if it's braking noises.. it should be coming from the front.
Old Jun 30, 2004
phil79's Avatar
well the sound is in the passenger rear, could it be a traction problem.....? if not the brakes?
Old Jun 30, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
only drums.
If that were true, my datsun would never stop because it has drum brakes all around.
Old Jun 30, 2004
phil79's Avatar
o and i dont have a rear camber kit yet will that effect anything....guys please help if not i'm thinking about changing all my brake pads and fixing the rear as well. I just got this car so i'm trying to fix all the things on it and thats one of them.
Old Jul 1, 2004
Sickboy's Avatar
Need way more info than that, but your first order of business should be inspecting those rear shoes. Negative camber shouldn't make noise like you're describing, but it will give you slightly less braking power.
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
