ATTN: telly or anyone with grey's endlinks... i need help!
Old Apr 14, 2004
RW_Blaze's Avatar
RW_Blaze is an unknown quantity at this point
yo telly i kno u got same setup as me.. grey's endlinks with 22mm and energy bushing... is urs making alot of nasty sounds... first sound is the bar hittin the exhuast and second is juss the the endlinks... seem like they're lost or like rattling everytime i hit a sml bump....
u kno that u have to setup the endlinks to its proper length.. i juss matched the length of grey's endlinks to factory one...
how did u setup urs and does urs make the same sound as im experiencing.. i hate yucky sound coming out of my car...
pls help! should i make the endlinks shorter in height???? to make it stiffer...
Old Apr 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I shortened mine (by eyeballing it) so that they would be 90 degrees on both joints when the car was lowered to the ground. Took a few tries due to springs settling, but I got it right finally.
As for the rattling - I don't have that problem with the endlinks. My exhaust pipe DOES hit the sway bar, so I just wrapped some rad hose around the sway bar at ALL points of contact with the exhaust pipe. The "clunk clunk" is gone, replaced by a barely audible thump.
Oh and btw as for the rattling, you may wanna try some lithium grease smeared generously on all moving parts of the endlinks, as well as in and around the sway bar bushings. My car is pretty quiet now. Nonetheless, I'm gonna raise the rear back up at least a 1/4" when I get my coilovers.
Old Apr 15, 2004
RW_Blaze's Avatar
hey dude u got a pic how ur setup up look like... if u can take a pic of ur endlinks how its setup now LOL or can u help me out fix it LOL i'll come whenever u wanna meet...
Old Apr 15, 2004
TeLLy's Avatar
Perhaps we can get together this weekend to check out this shizzazzle. I'll try to take a pic when I get home.
Old Apr 15, 2004
RW_Blaze's Avatar
yeah min for sure... imma bring it brack to the shop todai to get it checked.. if still same prob then yeah we'll meet up for sure this weeknd.... and yeah pls take pics if u can
Old Apr 15, 2004
TeLLy's Avatar
OK, but you must dance. Dance for TeLLy!!!
Old Apr 15, 2004
APRboy's Avatar
APRboy is on a distinguished road
That's wierd RW, i installed my RSX type S rear sway bar yesterday and am having the same noises coming from the rear of my car, sounds like metal to metal hitting....been the dealership today and they didn't fix crap, going to different one in the morning...
Old Apr 15, 2004
APRboy's Avatar
I haven't changed my endlinks though, maybe mine are effed up, hope that's the noise i'm getting, sounds really bad when i hit certain bumps...
Old Apr 15, 2004
RW_Blaze's Avatar
hey APR... first grease the bushings alot... then check if ur bar is hitting the exhuast pipe b/c that's the main cause of the sound with 19mm... and stock endlinks...
i got grey's endlinks on 22mm and the ball joint of the endlinks move swift and easy... which creates the metal on metal contact on the endlinks... so grey told me to put a vibration cushion between the washer and the balljoint.. ???
this is exactly what he said:
"The idea is to just cushion the moving parts so that through the movement you don't get any metal on metal contact."
i dunno if telly did that or u juss slap alot of grease on those moving parts...
i think tomorrow imma adjust the endlinks shorter (i have it set stock legnth right now) and slap alot of grease on those ball joints so it won't be metal or metal...
Old Apr 15, 2004
TeLLy's Avatar
Dude, my endlinks don't move enough to get metal to metal contact. If your car is lowered, then the distance from control arm to sway bar is lowered proportionately. Shorten the endlinks accordingly.
Old Apr 16, 2004
APRboy's Avatar
Just got back from the other Honda dealership here in London, and the driver's side endlink needed to be tightened. That's all...i had my car at the usual dealership i go to all morning, and they said it was fixed....bullshit!!! Damn dealerships, i'm not going to that one anymore...there is absolutely no noise now, thank god. Horrific sound that metal to metal noise...hope you get your prob. fixed RW.
Old Apr 16, 2004
RW_Blaze's Avatar
thanx bro.. yeah i think my problem is that the endlinks where set to the stock height so i got to make the lenght of it lower to adjust with my ride height and less movement from it...
hey telly sorry for al these questions but yeah could u give me an approximate lenght of ur endlinks or like how many threads is out... so i can follow the same...
Old Apr 16, 2004
TeLLy's Avatar
I won't have time till prolly tomorrow or Sunday, but I'll tell you there's not a lot of threads sticking out...
And of course you shouldn't refer to my car anyway, cause our drops are probably different, even if we had the same springs. My rear end is dumped, what with the box back there.
dhuff
Sep 28, 2015 08:35 PM
