Trunk leaking
Old Apr 11, 2004
sictoy's Avatar
sictoy is an unknown quantity at this point
Question Trunk leaking
I was planning on doing some cf housing for subs in my trunk but when i took out the carpt to get my measurment i found a puddle of water. The right side edge of the carpet was noticably soaked aswell. Have any of you had this problem?
Old Apr 11, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
my rear leaks to where its vented in the lift side of the trunk it pisses me off cuz now i gotta clean it . i guess ya cannot do much just bring a towel to soak it all up
Old Apr 11, 2004
AznSaint's Avatar
AznSaint is an unknown quantity at this point
there's a tub that goes through there for the water to leak out...
maybe the tube is out of place??
Old Apr 12, 2004
BoSS's Avatar
BoSS is an unknown quantity at this point
theres rectangular box kinda like a filter box in the truck right behind the rear driver side wheel well underneath the carpet. That'll do it. it'll get flooded with water during normal driving. Driving around for 2 days in the rain will do it. Its horrible cuz it made my car smeel like ****. I just covered it up with some plastic bags and duct tape. No problems so far....but my car still stinks....Take a look cuz mine happened after 2 years and when I went to investigate there was this 4X8 gapping hole. Again right behind the driver side wheel wheel right above the wheel.....
Old Apr 12, 2004
sictoy's Avatar
thanks for the help guys
BoSS: I know the box you are talking about but I got water coming from the other side. The passenger side.
I did a search and someone said the problem was a faulty sealing around the gas lid, could this be the problem?
Old Apr 13, 2004
AznSaint's Avatar
gas lid is on the driver's side.
then that wouldnt be your problem if you're sure it's from the passenger side
Old Apr 13, 2004
AznSaint's Avatar
i know there's a tube on the driver's side in the rear... i dont remember if there is one on the passenger side
i had the same problem over the winter too.
i had water in my trunk and i thought i just left something wet in there.. but when it happened for a 2nd time... kind of got me thinking.
but that was then... maybe i'll check my trunk to see if there are faulty leaking some where... o_O
Old Apr 26, 2004
dubz01si's Avatar
on each side of the car passenger and drive side theres 2 tubes running threw the sides of the car from the sunroof, one day when i get time ill have to see where they go to!
Old Apr 28, 2004
nogi1's Avatar
nogi1 is an unknown quantity at this point
i sprayed in dyna mate in my trunk doesn't leak any more
Old May 24, 2004
909's Avatar
909
909 will become famous soon enough
Trunk puddle Solution =
1. Remove the rear bumper.
2. Checked the hose assembly for clogs, leaks (sunroof drain) replace as needed
3. Remove Air Vent Assembly (passenger side trunk - hidden under bumper)
3. 2 part Epoxy seal the rubber vent flap SHUT (this flap allows trunk to vent)
4. Silicone the $hit out of it (no ventilation = no leaks )
5. Silicone the inside edge / perimeter - reattach to body via clips -
6. Seal the outside edge, with more silicone - repeat in trunk interior
7. Re-install bumper , trunk carpeting
Ta _ Da !!!! No mo leaks. Silicone dat biotch shut ta keep 'er dry.
cukaracha
30
Jul 26, 2015 12:01 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
hoofboy
Jul 17, 2015 04:27 PM
Kyles24
Jul 16, 2015 10:14 PM
Causemo
Jul 5, 2015 06:42 AM
