Installing OEM Sides
Old Jul 31, 2003
O1Coupe's Avatar
O1Coupe is an unknown quantity at this point
Well, I finally picked up my mounting brackets from Mississauga Honda yesterday. Tried putting it on myself and I couldn't do it.. so I took it to the mech across from my house, but he's clueless as well.
Could anybody help me out? Thanks...
Old Jul 31, 2003
Booohahaha's Avatar
BAD MON
how much were the brackets?
Old Jul 31, 2003
macrossranma's Avatar
macrossranma is an unknown quantity at this point
u also need double sided tape, perfer 3M, u mean u cant successfully have the sides in place and stick on or u have no clue how to install the brackets?, if u know how to install but it wont stick use the 3m tapes, heat it put the sides on and let it cool, dont let it get wet for 2 days
Old Jul 31, 2003
Booohahaha's Avatar
BAD MON
hahaha... in other words, stop by macrossranma place and have him give it a crack, right???
Old Jul 31, 2003
supYO's Avatar
supYO is an unknown quantity at this point
aside from the brackets u need the attachment plates
if u don't have those then u put two sided tape on the side skirts directly but dunno the strength that possesses
Old Jul 31, 2003
ASpec's Avatar
ASpec is an unknown quantity at this point
Just installed mine on the weekend.
I needed two sets of the the brackets for a total of 8 (4 per side) @ $30 per kit.
I first tried to mount them without using mounting plates or 3M tape, they will hold in place, but if you put any weight on them (like some-ones heel when getting out of your car, or going over a big bump in the road) it will move.
So, since we cant get the mounting plates from Honda (I tried 3 dealers all said they couldnt order them seperate from the skirts) you need to make your own.
All post a DIY of how I did mine.
Old Jul 31, 2003
Booohahaha's Avatar
BAD MON
alright i checked out a car with a oem skirt kit and all that car has are mounting brackets that like they are shaped like 2 !!!!
i dont see any metal plates on it.. and im also guessing its a replica side skirt.. cuz it felt like it was abs like plastic.
where would the metal plates go by the way??
Old Jul 31, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
i got my side skirt on without the metal plate and it rattle like a bitch on the highway and drive over a bump
Old Jul 31, 2003
Booohahaha's Avatar
BAD MON
really??
well..this is how im gonna do it. take the 3m tape and the "2" brackets and grab a bottle of silicone (clear one ) and dab it on where the 3m tape is and use some masking tape to hold it in place till it dries up. ... unless u guys have a pic of the metal plate and where it would go... >,<
Old Aug 1, 2003
O1Coupe's Avatar
Daaaamn.. so much work! Thought it would be straight bold-on...
Anybody wanna do the deed for me, for a case of beer?
Old Aug 1, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Oh crap, I'm gonna be installing a set tonight (like REALLY LATE)....hey 01Coupe, I'll let you know how I do. But in the meantime, can one of you kind gentlemen tell me where to obtain this 3M tape? Is there a special name for this particular kind that I should be looking for?
Old Aug 1, 2003
ASpec's Avatar
"3M mounting tape" in a red package, its available at home depot for about $5 a roll
Make sure you print off this installation guide.
http://www.handaaccessories.com/civic/02civsus.pdf
But I strongly suggest you make your own and mount 2 attachment plates at the rear end of the side skirt. Without them the skirts are very loose.
To make your own mounting plates:
1.Get some shower door tracking at home depot (about $10 for an 8 foot strip) Its aluminum, shaped like a U and about 1 inch wide.
2. have them cut it into 79cm pieces (you'll get three pieces from one strip of tracking.I only used two and my skirts are rock solid.)
3. mount the tracking to your car (after cleaning it and the car with alcohol), so that the the plastic hooks/rails on the back of the skirt rests in it. (you might have to do this a few times untill you get the mounting plate at the right height so that the skirt mounts flush while resting in the mounting plate, the skirt should have little or no play in it after the brackets are tightened)
4. While mounting the tracking, you should bend in the corners or grind them down, so they dont scratch your paint.
I hope this helps.
Old Aug 1, 2003
Booohahaha's Avatar
BAD MON
woo... thanks thanks
this is my project next weekend when i come back from the states.. haha u just saved me from slapping some silicone all over it >,<
hmm..basically we need 4 of these..
did u manage to fabricate the template????
Old Aug 1, 2003
TeLLy's Avatar
Time to go to Depot tonite!!!! I gotta grab some Lucite anyway.
Old Aug 1, 2003
ASpec's Avatar
No, I did it without the template, and I guess it wanst really a must have, It just took me a bit of extra time adjusting where to mount the fabricated mounting plates. You can line it up with your eye, by looking at the back of the skirt and where the skirt is supposed to rest when mounted.
I only used two mounting plates instead of four, (one per side mounted about 3 inches from the rear wheeel well on an Coupe). I really didnt think the front two were necessary, it will also save you $10 from buying another strip of the shower door track.
Old Aug 1, 2003
Booohahaha's Avatar
BAD MON
haha cool cool
thanks for the info. im gonna go shopping on monday when i come back from my trip. thanks hehe
Old Aug 1, 2003
iamfob's Avatar
sticky this thread cuz i am going ot need it later when i decide to custom make some metal plate for my sides
Old Aug 1, 2003
Chigga's Avatar
Chigga is an unknown quantity at this point
i work in a machine ship so i may be able to find some scrap metal, mill it to what i want and bend them to what they have to be at, but i need to know what they look like!
drill some nice holes..
Old Aug 2, 2003
TeLLy's Avatar
OK I did the install this morning using A-Spec's instructions. Went great, just need a couple more brackets which are on order. It holds solid tho. Thing is, I mounted the rails with double-sided tape, but I had to drive home from my buddy's house (where I installed it) in the POURING RAIN!!!!! Gaaaa!!!!!! I hope the tape is still sticky...
Old Aug 14, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
I went to home depot and could not find anything like the attachment plates. Can Anyone take a pic of what it looks like?
I ordered my brackets from honda so they should be here in a few weeks!
any ideas?
Old Aug 16, 2004
lid6662's Avatar
Bump any more info on the track to use!
Old Aug 16, 2004
TeLLy's Avatar
They look like sliding door track, about 1/2" wide by 1/2" high by like 6 or 7 feet long, made of aluminum. I'd take a pic but they're already on my car.
Old Aug 18, 2004
lid6662's Avatar
I have the skirts now now with only tape and and 1 screw each.... waiting on honda to get the 2 sets of brackets in....
Is the track allready in a u shape or do u have to bend it....?
I went to two different places home depot and coult not find them ahhhhhh
Old Aug 19, 2004
lid6662's Avatar
Bump
Old Aug 27, 2004
lid6662's Avatar
Ok just went to pick up my 2 set of brackets from honda
Now all I need is to make some attachment plates....
Any more info about what can be used ?[img]
Old Aug 27, 2004
DragonAce's Avatar
DragonAce is an unknown quantity at this point
shyt, glad i got the Veloz
all this "testing" goin' on is cool tho..good to see everyone helping each other out
Old Aug 28, 2004
03AzNsIlvaSeDaN's Avatar
03AzNsIlvaSeDaN is an unknown quantity at this point
Hey guys, so to put on the sides u gotta have mounting brackets and 3M tape?? like u cant do it with only the screws and bolts that come with the sides? ...so where can u get the mounting brakets?
Old Aug 28, 2004
Also, is it really hard to install? how long does it take?
Old Aug 29, 2004
lid6662's Avatar
One sideskirt will take me about 10-15 min to install one.....
You need to get the brackets from honda and u need two sets of the hardware kit!
Old Aug 29, 2004
how much are the brackets? and wutz the hardware kit??
