shock install help!
Old Jan 22, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
shock install help!
i'm having alot of trouble breaking the bolt in the rear shocks.
i've installed the fronts but i can't break the 17mm bolt attached to the shock.
if someone can give me a shop that will either break the bolt for me or just install them. i don't mind that much since i need an alignment anyway.
i've called a few places and they refuse to put in parts not bought from there cuz its not in their policy.
so if anyone can give me some help i'll be greatful.
im in northern va
Old Jan 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Try a breaker bar or something. I've never had a problem getting those bolts out, the torque spec is pretty light so its probably just rusted in.
An impact gun would probably get it out, but you'd still need to wiggle around with the bottom of the shock to get the bolt through the bushing.
Old Jan 22, 2006
pon55's Avatar
Liquid Wrench is your friend!
Soak, wait,soak,wait,and it will come off!
( NOT WD40)
Old Jan 23, 2006
civic01vtec's Avatar
I had that problem with mine. The bolt was rusted into the rubber bushing. Impact gun or bar wouldn't break it loose. When it turned, the bushing would twist too. I ended up cutting the shock off with torches.
Old Jan 29, 2006
tarheel365's Avatar
^it seemed that i had that problem at first too. the bushing would twist but when i let go it would spin it back to the original position. I just maintained pressure and used a lot of liquid wrench. and it finally gave in.
the other side was so easy to remove...it was disgusting......
Old Jan 29, 2006
ssmshortie's Avatar
im trying to install new springs on my elantra and i cant get that bolt off that holds the brake line and such
Old Jan 29, 2006
pon55's Avatar
( NOT WD40)
Old Jan 30, 2006
tarheel365's Avatar
haha yes u deserve rep
Old Feb 2, 2006
eddiechaps's Avatar
i love my morreale
try pb blaster
Old Feb 2, 2006
vacivic2005's Avatar
vacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the roughvacivic2005 is a jewel in the rough
pb works good
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
suburbanite
Jul 17, 2015 03:05 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
