Consequences of Redlining
Old May 21, 2003
  #31
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
This thread is lame.
Old May 21, 2003
  #32
dre2600's Avatar
I haven't got either turbo or NOS, barring the removed spare tire my car is bone stock. But the RX was 1st gen, N/A.
Old May 21, 2003
  #33
sc1golfr's Avatar
sc1golfr is an unknown quantity at this point
watch out for whiplash when redlining
Old May 21, 2003
  #34
Got Boost???'s Avatar
Am i the only one who finds this a little fishy.
I too drive an auto EX and im still wondering how you got it to 7500 RPM
ok will everyone please locate 7500 RPM on the tach pictured above, will you also notice that the redline STARTS at about 6750 RPM.
To answer the main posters question, going TO the redline is ok, your redline is a point your not supposed to cross, going past the redline is just plain stupid and is a great way to destroy a perfectly good engine
think of it this way
0 to 6750 RPM = Happy engine <-- happy because its doing what it was built to do
6751 and beyond = Sad engine <-- sad because its about to start spewing chunks of piston everywhere
Old May 21, 2003
  #35
Mbow's Avatar
Imo, the fuel cutoff is there to prevent you from doing any major damage. If it was that bad, the cutoff would arise sooner. It's just common sense.
Also, obviously, the harder you run the engine, the faster it will wear out/loose compression. It's just common sense. The same way that downshifting to slow the car down puts more wear on the engine and clutch than simply using your brakes.
However, the engine was meant to redline and one should never have a problem with doing so on occasion. A little spirited driving once or twice a week never hurt anybody...
Old May 21, 2003
  #36
Most cars have there fuel cut off shortly after the redline normally about 100-400 RPM's after the redline, the fuel should have cutoff long before 7500 RPM's in his car
Old May 22, 2003
  #37
Mbow's Avatar
Yea, I don't know how he arrived at 7500rpm. MY ex 5spd cuts off right at 7200....
Old May 22, 2003
  #38
After further testing i am now raising the :zbsflag:
Today i tried his little trick seeing if putting it in 2 will let you go past the redline, and it does let you go past it, well thats is until you reach 7000 RPM when your hitting the fuel cutoff. So his story about getting up to 7500 is complete BS.
Old May 23, 2003
  #39
Chrissy's Avatar
Chrissy is an unknown quantity at this point
to the thread starter: did you modify your rev limiter? i would second the last post before mine if you didnt. and yes, i also drive an i/h/e auto ex with a stock ecu.
Old May 23, 2003
  #40
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
rev limiter kicks in at 7 grand. only way to get it above that is downshift prematurely. can you even do that in an auto?
Old May 23, 2003
  #41
SlammedBlueEM2's Avatar
All Eyes On Z
How about posting an intelligent reply? (Or even rating the thread... that is an option.)
Anyhoo, I pretty much agree with everyone as mostly everyone pretty much said the same thing over and over. This goes for engine maintenance, too. But only one person disagrees that you can cause premature wear shooting the tach needle to the redline constant enough.
I just wanted to say... 7,500 RPMs? I drive a 5-speed and it won't go passed 7,000 RPMs in idle or in gear. On the other hand, if you upgraded your ECU I stand understood.
Old May 23, 2003
  #42
dre2600's Avatar
No, I didn't modify the rev. limiter, it starting to cutoff approaching 7200rpm, but a block or two after the lights theres a pretty decent downhill incline, so it was still accelerating, though I think hitting the rev limiter, but still in 2nd gear.
Old May 23, 2003
  #43
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
I've taken my car to 8,200 RPM'S ....but then again I drive a GS-R....sorry that was my sad attemtp to mention that I drive a GS-R....but without further ado, I also call BS (I rarely ever call BS on anyone's thread) on the 7500 Redline, the only way he could have done this, was misshifiting which, I don't think you can do in an Auto....to the topic starter: can you please enlighten us if the 7500 is true, what you did to change the fuel cutoff??, how did you misshift?....I'm thinking, you may have saw 7500 but it was actually only at 6500, maybe a typo???
edited to correct spelling error
Old May 23, 2003
  #44
All Eyes On Z
It must sound like it's gonna blow up after 7,500. I remember when my friend redlined his GS-R... it doesn't sound too pretty but I do like the fact that it can rev that high.
On the other hand, I still haven't figured out why the B18C5 doesn't sound like it'll blow up compared to the other high revving B engines... B16 included.
Old May 23, 2003
  #45
aznsmtboy's Avatar
well, I don't know how a engine that's going to blow up sounds like, but that's definitely not the feeling that I get when I rev that high....maybe something was wrong with your friend's car???? Have you been in more then one GS-R???
Old May 23, 2003
  #46
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
rx7? 3/4 carlength? was he towing another car behind him? hehe jk... bad wear to head for redlining
Old May 23, 2003
  #47
dre2600's Avatar
It was a first gen Rx-7, I gotta keep saying this, N/A ones only had 140hp and weigh more than a Civic.
Also, I'm not bragging about hitting 7500rpm, I was just kinda worried about it.
Old May 23, 2003
  #48
All Eyes On Z
It's just that the engine sound gets very high pitched after 7,500 RPMs. It is a 97 GS-R and unfortunately that's the only GS-R I've been in. We had a member with a 99 Si before (NeoMagus) who pretty much thought the same about his Si engine.
Nah, trust me his motor is all good. All he has on it is an intake and header though.
cferry7
Oct 3, 2015 04:33 PM
Stock 99
Sep 5, 2015 06:06 AM
dantheman42
Sep 4, 2015 01:10 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
Jeeves
General
18
Jan 31, 2002 08:18 AM
