b20 vtec? or ls vtec?
Old May 12, 2003
imPHOrt racer's Avatar
imPHOrt racer is an unknown quantity at this point
Whats quicker b20 w/ vtec or ls vtec? im talking basic bolt ons with maybe cams but nothing big...and what would be the big diff in them? meaning 1/4 times...I know b20 is gonna be more reliable but prob lose little power compared to ls what u guys think? let me know thanx
Old May 12, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
umm the ls engine doesnt have vtec....
the turbo ls engines are on average faster than b20 frankensteins
Old May 12, 2003
Chrissy's Avatar
Chrissy is an unknown quantity at this point
or if you want low end like off the line, but with a smaller power band, get the b20. i would think it is better for turbo since it has already a lower compression and longer stroke. bad thing is its a tad heavier
Old May 12, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
ur best bet if u wanna go n/a is to go b20. if u wanna turbo stick with the LS
Old May 12, 2003
Logan3024's Avatar
Re: b20 vtec? or ls vtec?
BOTH!!!!!!!!!!!
id say do a B20B swap, With LS camshafts. Around 7 extra hp with LS camshaft over stock B20B cams. Id also recommend a LS tranny for this swap
Ten turbo that bad boy!
Old May 12, 2003
Logan3024's Avatar
Of course a turbo LS is gonna be faster. Its not gonna be faster than a B20B with a turbo
Old May 12, 2003
HondaLuver's Avatar
Its a celebration bitches!
i say go with a B20 NA, it is probly the most reliable. i haven't heard too many good stories with ls/vtec. i would rather go with a gsr turbo set up and a type r tranny...
remember it all matters on how much money you have to spend
Old May 12, 2003
Logan3024's Avatar
I have to disagree with you on this, For N/A get either a B16 or B18 or interswap a b16 and 18
You know b20b only produce's 146 hp and 133 tq Stock!
a B16 PRODUCES 160 HP
JUST BECAUSE ITS A BIGGER ENGINE DOES NOT MEAN ITS GONNA BE FASTER!
ONLY GET A b20 if your willing to spend some hard earned bucks to get this thing up to par!!!!!
A N/A B20 with respectable numbers is gonna take some work! and money!!!!!!!!
If your going N/A DO NOT GET A B20!
Old May 12, 2003
aznsmtboy's Avatar
aznsmtboy is on a distinguished road
if you add a VTEC head the the B18b block, you will have an LS VTEC setup...of course it's a bit more complicated then just switching the head..........
The B20VTEC will be more torquier then the LSVTEC.
Old May 12, 2003
d17a2outlaw's Avatar
d17a2outlaw is an unknown quantity at this point
my friend has a b20/vtec in his rex and stock(no add-ons or anything) ran a 13.4 in the 1/4. but it really depends on what you want to do with the car go turbo or n/a. if you want n/a go with a type-r engine, gs-r, or if you want to a b16. if you really want to do something go do a mini- me swap (b18c1 bottom end and b16 head) some call it the prro mans type-r. but if you want to go turbo just go for the ls. you will make more power with the b20/vtec than the ls/vtec, but you will have to find someone you know that wont f*** up your engine to do it for you unless you want to do it. remember 13.4 with the b20/vtec. or just go k24 with k20 head. haha.just my .02 cents.
Old May 12, 2003
aznsmtboy's Avatar
one of the members of a forum that I'm on more frequently (www.gs-r.com) has an integra with a B20B Vtec running 18psi, dynoed 508 whp 366 lbs/ft torque;
here is the link to his dyno sheet
HERE
if you scroll down, there are some pics of the teg too.
Old May 12, 2003
Chrissy's Avatar
HERE
wow enough to whip a middle class ferrari. , but not top end unless you got some serious gearing
Old May 12, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Chrissy,
love the "quote sig" you come up w/ everytime!!
Old May 12, 2003
b y r o n's Avatar
b y r o n : t i b u r o n
b y r o n is an unknown quantity at this point
ls v tech is VERY UNRELIABLE! you'll blow in like... 6 months..
Old May 12, 2003
Chrissy's Avatar
Originally posted by Da2K1
Chrissy,
they either come from my professors, internet, or just my wacky self.
Old May 13, 2003
thanx guys, i acutally found a dood whos sellin a 30K b20 motor turboed with t3/t4 runnin high 12's selling for $8,500 so im gonna check dat out, if i dont like it im jus gonna settle for this b20 swap in ls integ. and work from there
Old May 13, 2003
aznsmtboy's Avatar
first of all it's LSVTEC, and I beg to differ, if it's built properly, the LSVTEC will last for much longer then 6 months......it's just that too many people don't know how to build it properly and **** goes out within 30,000 miles.
Old May 13, 2003
dragoon's Avatar
www.importbuilders.com in case you decide not to go turbo.
Old May 13, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I'm not exactly sure you can make this comparison fairly. If there was a stock VTEC B20, it would be pounding B16s into the ground all day long. That 146 HP is with fixed timing.... no VTEC, where as the B16 is running with VTEC and only puts out 111 ft-lbs of torque.
So find out what a B16 would have with fixed cam timing or a B20 that has VTEC and try again... because your comparison isn't fair. Its like compairing the LS engine to the GS-R engine. VTEC vs. no VTEC and look at the difference it makes.
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
chiquita.banana
Sep 24, 2015 09:42 AM
Hatchness
Sep 14, 2015 09:02 AM
