K24 Frankenstein
Old Apr 28, 2003
  #31
dragoon's Avatar
Originally posted by Chrissy
k24?? on our civics? can we say understeer?
can we say not as bad as a VW with the VR6? it'll be aiiiiight
Old Apr 28, 2003
  #32
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
A VW w/ a VR6- that can't handle w/ the stock suspension at all!
A good set of aftermarket suspension components will fix that! (Progress currently makes a set for a B18 swap into the older civic; maybe they'll do one for this, if it becomes popular) Or you could go the cheap way & pull the F. sway bar & put a stiffer R. sway bar.
Old Apr 28, 2003
  #33
Jodster's Avatar
Post Whore General
The K24 has the same RPM range as the K20A3 so its not that bad. But I would rather look into getting a TSX K24 that has Vtec and get a hondadata to flash to help that out.
Old Apr 28, 2003
  #34
cambo's Avatar
I wish I was asian
Acura TSX has a k24 with 10.5:1 compression. thats how it gets 200 HP
Old Apr 28, 2003
  #35
dragoon's Avatar
why not be like the guy on the first page, andput the k20a2 head on the k24? and all k24's have i-vtec, including the cr-v ones.
Old Apr 29, 2003
  #36
RoadRunner's Avatar
man i'm totally lost in this topic
Old Apr 29, 2003
  #37
Chrissy's Avatar
Chrissy is an unknown quantity at this point
so if i ever swapped in a k24 and fi'ed for this POS d17, i wonder how my car would handle afterwards. all i know is that i'd be real good for the quarter track, thats for sure.
Old May 2, 2003
  #38
briang's Avatar
briang is an unknown quantity at this point
The K24 block does not mount different than the K20 block. A K24 dropped right in the EP. The major difference in the two blocks is that the K24 is a little bit taller.
Even though it will bolt directly into the EP, and I know because I have one in my EP, it does not go in the Sedan and Coupe with our mount kit. The K24 uses a different bracket on the passenger side of the motor. We will have to make a different passenger's side mount to mount it in with our kit.
The K24 engine will actually become far more common place than the K20s because they not only come in the CRV, but will be in the TSX, Element, and of course the ever popular Accord. I believe there will be 300,000+ cars with K24s by years end on the road.
The future is bright.
brian g
Old May 2, 2003
  #39
trick000's Avatar
trick000 is an unknown quantity at this point
so the k24 already has an i-vtec head... and I'm guessing it's got the k20a3 version of it which only has the third lobe on the intake side or something like that...
Old May 3, 2003
  #40
briang's Avatar
That depends, the Accord, CRV and Element are like the Civic Si's VTEC. The TSX has VTEC like an RSX Type S. The all have K24A blocks.
brian g
Old May 3, 2003
  #41
dragoon's Avatar
brian, will hasport ever make a mount kit that doesn't require the subframe?
if not, will the accord/crv/tsx subframe be compatible like the EP/RSX's subframes?
and will anybody be making an aftermarket subframe?
Old May 3, 2003
  #42
ViNRoCk8's Avatar
#1 S2000 Fan
Damn I hope so.....Or I hope some companies start to make it a little easier.
I just keep telling my self......Patience is virtue
Old May 3, 2003
  #43
dragoon's Avatar
yes yes, that's what i tell myself too. i also tell myself "you're too poor to do this"
Old May 3, 2003
  #44
briang's Avatar
Subfarme
Not Likely, to do the swap without the subframe would require redesigned and much more expensive front and rear mounts and a custom header.
Call Honda and check the part numbers for the subframes on the RSX, Civic Si, Accord, CRV and TSX. See if any of them mattch. If they are not the same, you will have to wait until I get some and check to see if they interchange. Maybe over the next 6 months I will be able to get to it.
brian g
Old Jun 9, 2005
  #45
HondaLuver's Avatar
Its a celebration bitches!
its like 600 a subframe
RiceRocketeer
Engine Swaps
80
Dec 6, 2004 07:45 AM
lkm
Engine Swaps
17
Oct 13, 2004 09:35 PM
Texas Rice
Engine Swaps
May 3, 2004 10:34 AM
Texas Rice
Mar 31, 2004 10:46 PM
GoOkStA
Jun 19, 2003 01:29 PM
