Help! Can the dealer void my warranty because of this?
Old Apr 23, 2003
opto_isolator's Avatar
I had a problem trying to install my X-brace. The front drivers side control arm bushing was froze up. When I tried to unbolt it, the bushing tore up. Mind you I never did get more than 2 bolts out of the subframe.
Fast forward to today. I brought my car to the dealership to have them fix it. They are saying it is not covered under warranty due to aftermarket parts, or because I tried to take it apart myself. They are now saying that the control arm is bent as well - and I did nothing with the control arm.
Does the Magnuson-Moss Warranty Act protect me here? Or am I liable since I initiated taking the vehicle apart? My argument is that the bushing froze up, and that this would not have happened if it did not - therefore I should be covered under warranty. Heck that may even be why the control arm was bent.
I don't know what to do....I need advice.....
Old Apr 23, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
you answered your own question man, if the dealer said you voided warranty then you did. all kinds of mods can and cant void your warranty depending on the dealer.
Injen
Old Apr 23, 2003
dirtEsanchez's Avatar
Better Then God
dirtEsanchez is an unknown quantity at this point
Nope. You f*cked with the ish without knowing what you were doing and screwed it all up. Only thing you can do is take the car to another place for a second opinion on how to repair your mistake.
Thats why I take any suspension work to the pro's....engine work I can do myself, but when it comes to suspension, that is what keeps me on the road and I don't mess wit dat.
Old Apr 23, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I'm not sure.
Take it to the another honda dealership to do the work.
Also; don't tell them about the x brace issue.
That is my 2 cents
It is obserd that they stated the control wasn't convered because of a simple bolt on part.
F*&^ing tight wads!
Old Apr 23, 2003
wtf?
What do you mean - without know what I was doing? I knew exactly what I was doing - removing the control arm bolt. It should not be a big task to remove 1 damn bolt, esp on a car with only 19,500 miles on it! The fact still stands that the bolt was frozen up - I say that they should at least cover the parts since they have no way to prove that I f@cked up the bolt. How can they prove that I siezed the bushing sleeve on? There is no way.....
As far as things go - I'm just mad. This 10 minute job should have not cost this mutch and taken this long. Dammit.
Old Apr 23, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
just a btw, control arm bolts are often very hard to unbolt because they are generally torqued to very high specs.... and yeah, try another dealership....
Old Apr 23, 2003
Dr5D's Avatar
the dealer will never want to cover anything! never tell them anything you have done, and always deny that you were doing whatever they are accususing you of!
but since you already failed there, i guess just go to another dealer
Old Apr 23, 2003
Brush dirtEsanchez off he can be sometimes just like his picture.
You know what they say opions everyone has one
Old Apr 23, 2003
S2000man01's Avatar
O RLY
Injen
wrong. mods can only void a warranty for a part they directly affect.
as for opto, you're kinda screwed. If what you were doing to your car in removing that bolt was NOT considered routine maintenance, then you were going somewhere you shouldn't be according to your warranty. even if the bolt was frozen up, it doesn't matter, because you're the one that broke it. and since you removing that bolt in order to install an aftermarket part was necessary, you are not covered. You might be able to find a dealer that will fix it for you, but it's not likely.
Old Apr 23, 2003
injencivic's Avatar
[QUOTE]Originally posted by S2000man01
[B]wrong. mods can only void a warranty for a part they directly affect.
Ya i know that, i was just giving a general answer to the question
Injen
Old Apr 23, 2003
Better Then God
I have a fan. lease:
Old Apr 23, 2003
oh well
Thanks for the responses...The dealer fixed it - new control arm bolt / and bushing + labor = arm and leg......
Note to self - use impact wrench next time!!
Old Apr 23, 2003
S2000man01's Avatar
O RLY
[QUOTE]Originally posted by injencivic
[B]
Injen
ah, then I misread what it was you were explaining. My bad, good sir!
alaga
25
Aug 13, 2015 04:42 PM
carid
Aug 8, 2015 05:05 PM
masongap
Aug 4, 2015 09:20 AM
barryaz1
Jul 30, 2015 10:50 AM
