Storing your car away!
Old Apr 22, 2003
Andrew's Avatar
Andrew is an unknown quantity at this point
k, i have done my oil change, washed inside and out my car, filled the tank....
now, i have parked my car in reverse with bricks supporting the rear wheels, and no e-brakes. My question is, before i turn on my car 3 months later, do i put it into neutral before starting the car, or do i start it in reverse gear, and than quickly shift into neutral as soon as the car starts in reverse?
Old Apr 22, 2003
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
disconnect your battery so u will still have power
put in netural before u start it up, that way when it starts the oil gets moved around inside the transmisson cases allowing shift forks and synros to move freely when you first move it.
Old Apr 22, 2003
R3DL1N3's Avatar
youre actually supposed to leave it in reverse while youre away
Old Apr 22, 2003
R3DL1N3's Avatar
and if u have a car cover id suggest using it
Old Apr 22, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
Why do you leave the car in reverse...never heard that. And your gas goes "stale" after awhile. So why would you fill up your tank and then let it sit for 3 months while the gas breaks down? Bad for your engine...
Old Apr 22, 2003
Andrew's Avatar
i have no clue, but thats what it says in the owners manual. any honda tech's got an answer to this brain guzzler???
Old Apr 22, 2003
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
i remember this from a bmw dealership that my dad uses. they said that when your store it you want to have a full fuel tank because, a half empty tank of fuel will attract water vapor into the tank and then into the gas.. When you store it full of fuel it makes it so that there is no room for the water to get into the tank. It also helps resist corrosion on the inside of your gas lines and the tips of your injectors. Water in your gas is what causes it to go stale... this is what the bmw dealership told my dad before storing our M5..
Old Apr 22, 2003
EM2HK1's Avatar
EM2HK1 is an unknown quantity at this point
ya im kind of curous to know why not leave the car in reverse? and why not have the e-brake up?
dragonsblood
Apr 27, 2015 12:28 PM
LionSpratt
Apr 26, 2015 01:02 PM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
