best acceleration in various gears...
Old Mar 10, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
ok.... well here goes
for 5spd correct me if im wrong
1st gear 0-40mph medium acceleration
2nd 40-60 high
3rd 60-80 medium high
4th 80-120 high
5th 120-? (im gussing 135) low
so when you are cruising within those ranges... you can shift to any of those gears...
so if you are going 60.. you can downshift to third... and be ok
now trying to accelerate in 5th is a bad idea.. cause you really cant pick up speed as fast as going in 4th...
hope this helps in playing tag on the freeway...
*edit* these figures are for fast acceleration, so like to redline... in each gear
Old Mar 10, 2003
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
2nd and 3rd are my hauling *** gears. ~ protege 5.
Old Mar 10, 2003
Diemos's Avatar
Diemos is an unknown quantity at this point
you rounded up on some of those figures, but pretty accurate. within 2-3mph difference
Old Mar 10, 2003
abmerop18's Avatar
Jam out with your clam out.
[QUOTE]Quote
[hr]Originally posted by: WannaBFast
135?? my car is electronically limited to 118? when i get to 118 i feel the car shake once then it begins to cruise at 118 and 4750 rpm. i have a 5-speed 2k2 lx coupe. can anyone else with the same car as me get up to 135? how do you get up that fast?
Old Mar 10, 2003
WannaBFast's Avatar
well i have an ex sedan.. and the fastest ive got was like 125...
Old Mar 10, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Quote
2nd 40-60 high
4th 80-120 high
*edit* these figures are for fast acceleration, so like to redline... in each gear[hr]
These values seem off to me, since 1st gear has the fastest acceleration, and 2nd has the next best and so on down the line. That's the way our transmissions work as well as any other cars. Not to mention the faster you go the less horsepower your car can use to actually accelerate your car. Lastly, My car tops out at about 35 in 1st. In a car with a close ratio transmission, acceleration should be about the same through each gear, but the top speed is much less. Our cars do not have this type of transmission, though they claim the si does.
I made a spread sheet in excell that calcualtes out the speeds at a given rpm, and I got pretty similar values for speeds in the given gears.
-Mark
Old Mar 10, 2003
WannaBFast's Avatar
Quote
[hr]Originally posted by: Renamazazo
-Mark[hr]
well the reason why it can accelerate is because of the torque band... if you have a 4-2-1 header you will have more low end torque therefore if you try to accelerate close to redline, you wont pick up speed as when you are starting out. as opposed to my setup, meant for high end performance... if you can call it that...[IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 10, 2003
Dr5D's Avatar
i think it depends on the model your talking about, i think
ive got a two door 2001 ex and ive gone about 130 slightly downhill on the highway, and i think 4th just goes to about 110, but i my be wrong cause i havent done that for awhile
Old Mar 10, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
Interesting, mine is more like
0 - 35 1st
35 - 55 2nd
55 - 80 3rd
80 - 105 4th
105 - ?? 5th
But I don't think that my fifth will go up to much over 120. I know I'm at 4000 when I am doing 80mph. Is that about right for everyone?
Old Mar 10, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
i have a 2002 DX 5 sped and rev limiter come on at 20 in 1st but 2nd last till 60 mph. WTF?lol
Old Mar 10, 2003
WannaBFast's Avatar
Quote
[hr]Originally posted by: outdrsmn80
0 - 35 1st
35 - 55 2nd
55 - 80 3rd
80 - 105 4th
105 - ?? 5th
But I don't think that my fifth will go up to much over 120. I know I'm at 4000 when I am doing 80mph. Is that about right for everyone?[hr]
yea thats about right for me... but it all depends on everyones trim level... and remember.. this isnt normal acceleration... more like extremely high acceleration...
Old Mar 10, 2003
Civicly02's Avatar
yeah my RPM is high when I'm going about eighty. It is like 4000 rpm. Is this normal because my 2000 civic the rpm is like 3500
Old Mar 10, 2003
born2xLr8's Avatar
Quote
0 - 35 1st
35 - 55 2nd
55 - 80 3rd
80 - 105 4th
105 - ?? 5th
[hr]
You guys sure ride those high rpms. When I'm just cruising on the street, I usually shift when I hit 3500 rpms
Old Mar 10, 2003
RyzRocket02's Avatar
RyzRocket02 is an unknown quantity at this point
I dunno about pulling 40 in 1st and 60 in 2nd. When I run to 60, I hit reds. But, I'm always in the upper 3rd gear when I actually hit the 60 mark. I think in 2nd, I shift somewhere like 50-55. I think 1st tops out at mid-30's. But then again, I haven't riden up my gears like that in a while. I shift under 3k cuz I can't afford gas.
Old Mar 10, 2003
Friedrice's Avatar
Friedrice is an unknown quantity at this point
Quote
Quote
0 - 35 1st
35 - 55 2nd
55 - 80 3rd
80 - 105 4th
105 - ?? 5th
yea thats about right for me... but it all depends on everyones trim level... and remember.. this isnt normal acceleration... more like extremely high acceleration...[hr]
Extremely high acceleration...[IMG]i/expressions/laugh2.gif[/IMG].... good one...[IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 10, 2003
WannaBFast's Avatar
Quote
[hr]Originally posted by: Friedrice
Extremely high acceleration...[IMG]i/expressions/laugh2.gif[/IMG].... good one...[IMG]i/expressions/laugh2.gif[/IMG][hr]
well i mean seriously.. what i meant by that is when you are trying to go as accelerate fast by running close to or at redline
Old Mar 10, 2003
outdrsmn80's Avatar
Well obviously I don't drive like that everywhere I go. I just mean that when I put my foot down occasionally, that's about where the redline is in the different gears. Driving around the beltway in DC you need to accelerate off the onramps with some speed sometimes or else you will get run over. Plus it's fun.[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 11, 2003
CGodwin3103's Avatar
I Am Legend
CGodwin3103 is an unknown quantity at this point
Well, me 2001dx coupe.
I hit it and I dont hit red till about 33-37 or 38
2nd is between 35-about 55-63
3rd I run till around 82 or 83 i think, maybe a few more
4th can land me at about 100-110
and fifth is like the last 23 or 24.. I havent taken my car over 105 since I toped it at 134.34 (.34 is a guess as the actually position of the pointer was just a hair over 134)
I might be a few mph off, but probably no more than about 4, I run it enough to have a good feel about the speed. (This is in the context of racing, actual pull as far as just highway driving... I pulled past an mdx just after about 105 on the way home last saturday night, yes again I was running him, but from a rolling start say 65-75 mph.)
Old Mar 11, 2003
CapYoda's Avatar
Escaped Convict
argh. there's a post about this but I can't find it.
there's a site that shows the gear ratio, and the respective top mph you can reach in that certain gear...
for a ex 5spd,
2nd - 58 or 59 mph (can't remember which, but I've downshift before at 55 and its almost at redline)
3rd - 83 mph...
the rest I cant remember. lol.
1st gear might be 33 or 37mph.
Bruce2
Sep 27, 2015 08:45 PM
tropicola
Sep 25, 2015 07:02 PM
charmon4815
General
Sep 22, 2015 08:00 AM
dantheman42
Sep 4, 2015 01:10 PM
